Go Back   Home > Forums > > > >
Commercial Projector Ballast Bypass Guide
Old 14th October 2012, 06:15 PM   #121
Ponfery is offline Ponfery
lotuspod, did you have any luck with the bypass?
Old 15th October 2012, 09:28 PM   #122
lotuspod is offline lotuspod
No luck yet. I have someone from another forum helping. Thus far we've only devised a way of testing the opto's at stock operation. Do you have a similar model? If you'd like to follow the progress or contribute.... PLS Help. DLP Bypass Lamp - Osram Lamp Control Board - 5-pin UART Communication
Old 13th November 2012, 09:55 AM   #123
sena9922 is offline sena9922  Serbia
Thank you for the advice, I am unlocked my Infocus projector x1
Old 14th November 2012, 06:04 PM   #124
StiffCookie is offline StiffCookie
Default Optoma HD65
Hey guys,
I have an Optoma HD65 that really doesn't want to turn on! It uses SCI to monitor Lamp status and I just wondered if anyone could figure how to bypass it so I can use any lamp I like? The grounding method doesn't work. I've attached pics and labelled them as best as I can, couldn't find a service manual anywhere to help though :/ .
Thanks in advance
http://s5.postimage.org/r4xy9yp13/1_...p_Side_SCI.jpg
http://s5.postimage.org/peex8h7hz/2_...m_Side_SCI.jpg
http://s5.postimage.org/ha6t3ql2v/3_...p_Side_SCI.jpg
http://s5.postimage.org/gypcqz4mv/4_...m_Side_SCI.jpg
http://s5.postimage.org/84yg9vho7/5_...Driver_Pic.jpg
http://s5.postimage.org/tsrzy27g7/6_...iver_Pic_2.jpg
If any more pics are needed, just let me know and I'll upload them straight away!
Old 22nd November 2012, 04:30 PM   #125
marmota is offline marmota  Dominican Republic
I have problem bypassing Viewsonic PJD5152.
I connected lamplit ( PIN1 ) to ground but projector going shuts down.
I need any hepl please.
Old 22nd November 2012, 06:15 PM   #126
I have a problem with a wheel color I using a halogen lamp 100w 12v.Wheel increase the speed as soon as I turn on the lamp,I think my real problem is fotosensor.I need help, my projector is the InFocus X1a.
Product data
• General Characteristics
Philips Code 13100
Cap-Base GY6.35
Cap-Base Information 15
Bulb T4 [T4: .434 inch / 11mm]
Bulb Finish Clear
Operating Position any [Any or Universal (U)]
Rated Lifetime
(hours)
4000 hr
Rated Lifetime
(years)
4 an
• Light Technical Characteristics
Color Rendering
Index
100 Ra8
Color Temperature 3000 K
Color Temperature
Technical
3000 K
Luminous flux lamp 2200 Lm
Rated Luminous Flux 1850 Lm
Luminous Efficacy
Lamp
22 Lm/W
• Electrical Characteristics
Lamp Wattage 100 W
Lamp Wattage Technical
100 W
Voltage 12 V
Lamp Current 8.33 A
Dimmable Yes
Rated Wattage 100 W
Starting Time 0.01 (max) s
Warm-up Time to
60% Light Outp
instant full light
• Environmental Characteristics
Mercury (Hg)
Content
0.0 mg
• Measuring Conditions
Switching cycle 16000X
• Luminaire Design Requirements
Pinch Temperature 350 (max) C
Bulb Temperature 900 (max) C
• Product Dimensions
Overall Length C 44 (max) mm
Diameter D 12 (max) mm
Overall Width E 12 (min) mm
Light Center Length
L
30 mm
Overall Height H 44 (min) mm
• Product Data
Order code 924040017101
Full product code 924040017101
Full product name Capsuleline 100W GY6.35 12V CL
4000h 1CT
Order product name Caps 100W GY6.35 12V CL 4000h
1CT/10X10F
Pieces per pack 1
Packing configuration 10X10F
Packs per outerbox 100
Bar code on pack -
EAN1
Old 1st December 2012, 09:07 AM   #127
spinnerwestside is offline spinnerwestside
hello i have a sanyo xe40
i have tried grounding the the close to 3.3v but the projector
dose 3 spin ups and then red light
then i tried grounding each wire and still 3 spin up then red light
1 wire gave instant red light
so can anyone help me bypass this
Old 15th March 2013, 11:35 PM   #128
nr002541 is offline nr002541
I have posted on another forum projectionforums.com • View topic - Sanyo PLC-XE31 ballast bypass but I have a Sanyo PLC-XE31 I want to bypass and im not 100% what cable needs to be grounded. pictures are in other post
Old 26th March 2013, 09:49 AM   #129
smokey76 is offline smokey76  South Africa
smokey76's Avatar
Need help with a sharp xv-c10m. I want to bypass the ballast or get it working again
It shows the power is on but nothing else. How can I test that the lamp is working or not. want to also ghange the lamp to a more afordable option if posible and would love to have advice form the forum on that please
Old 30th September 2013, 02:30 PM   #130
oggioffshore is offline oggioffshore  Norway
Talking Dell 3200mp
Hi, new to this forum.
Hope someone can help ...
My Dell 3200mp only lights up like 5- 10 seconds before it shuts down.
Lamp light comes on.
i will try to bypass the ballast and see.If i can manage to to that.
Wonder if any in here have done that with this model.Or have experience with dell pj`s... etc
Some say its the lamp, and other the ballast, or lamp driver.
Hard to tell though.
The few seconds its on, its very bright and clear picture. And even the lamp are over its life span, it still would be possible to use the pj.
Commercial Projector Ballast Bypass GuideHide this!Advertise here!
