Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 23rd December 2011, 04:49 PM   #101
Bohanna is offline Bohanna  United States
Originally Posted by SeattleMatt View Post
Hello, I am new here and I am trying to bypass the lamp on a Sanyo PLV Z2. The projector lamp ballast comes out with only two contacts/wires so I don't know how it detects the bulb. I am planning to convert this to LED using a Cree XML.
I think the photos and notes I posted above should help you keep the projector up and running with the lamp out
Bohanna
Old 24th December 2011, 07:19 AM   #102
So, I'm having some trouble identifying which part of my projector is the ballast and which wires are going to it. Based on the schematics it looks like the ballast is somewhere in here.
The 2 thick gray wires go around the projector to the bulb. The three white wires go from one small board to the other.
Any guesses on which part of this is the ballast? Or should I be looking somewhere else?
Old 27th December 2011, 10:35 PM   #103
I updated the photo to be more clear.
Old 28th December 2011, 05:18 PM   #104
The Ballast is the board that has the two large wires that go to the lamp. I beleive that the connector you are looking for is the one with the clear plastic see through jacket located Just under the "IR" letters in the 3 wires connect red text on your picture.
Bohanna
Old 28th December 2011, 05:24 PM   #105
Ok, that was my guess too, one of the 3 white wires then, specifically the one with the clear jacket? And I just run this wire to ground? I am going to put my mm on there tonight and check for the 3.5v. Although the wiring diagram seems to indicate there is a 5v, but not a 3.5v.
Old 10th February 2012, 09:17 AM   #106
EPSON EMP-74 LED MOD
here is my post for epson emp-74 lamp hack with led mod
Old 12th March 2012, 02:23 AM   #107
hi, i have a toshiba tdp tw90
i did the steps exactly and none of the wires worked.
is there anything i need to do differently for a toshiba
Old 27th April 2012, 10:15 AM   #108
Hello I have a "toshiba tlp s10 projector" with no ballast. Can i mod it?
And how?
Old 20th May 2012, 01:42 PM   #109
Question toshiba tlp s10
hi
I have this projector and need ballest voltage in and outgoing information , from how many voltage are coming to lamp balest adapter and then how many voltage are going to bulb . i want to modification with XENON HID KIT SATZ H1 6000k
i have modification the lamp reflector .
Old 23rd May 2012, 11:55 AM   #110
Default toshiba tlp
Hi is there no one can give any help
Page generated in 0.09016 seconds (78.73% PHP - 21.27% MySQL) with 11 queries
