Go Back   Home > Forums > > > >
Commercial Projector Ballast for DIY?? Need Electronic Wiz!!
Old 8th April 2009, 03:05 PM   #11
crazifunguy is offline crazifunguy  United States
Well I took this outside in the garage and did some testing off the 220V. The 150w osram powerball gets blinding bright out of the stock reflector.
I think the arc is too big to be focused properly. Its odd I placed a white object about 1 inch from the reflector and it was blinding bright. I think the LCD projectors still need a point source when I tested in a projector it was very dim compared to an auto hid with a much smaller arc gap. I was assuming that these projectors just needed the light area flooded and the lenses took care of the rest.
Old 2nd December 2009, 07:04 AM   #12
Sebka33 is offline Sebka33  France
Hello,
I need to use the ballast from my old IBM ilc200(lp530 projector's clone) without the rest of this projector.
So, I want to extract the IBM's ballast and use it with a diypro.us bulb for a other application.
I think it's possible, but I don't know which opto to bypass...
Can you help me please ?
(sorry for my english )
Sebka33, from France.
Old 4th December 2009, 06:57 AM   #13
I found the answer to my question.
bye !
Old 17th December 2009, 03:14 AM   #14
thedarlington is offline thedarlington  United States
how did u guys bypass the switch to turn onthe ballast independently? im currently in the same pickle but need to test a used ballast to see if it works, btw, how much of a difference did u see before and after the focused point? i too thought you only needed to flood the lens with light
Old 25th December 2009, 11:20 PM   #15
These ballasts dont work well with large arc gaps. They have very sensitive current sensing. Someone needs to figure out how to change the current and wattage to make it adjustable.
Commercial Projector Ballast for DIY?? Need Electronic Wiz!!Hide this!Advertise here!
Electronic BALLAST medogrizli Power Supplies 0 27th August 2006 06:03 PM
