hi all,
i learn much in this forum. so thx to all ;-)
this is my not yet finished prjoject:
the rusult (looks better in real life ;-) my damn camera:
this is my case (not ready yet):
the only problem i have:
the reflektordesign i use is not the best, but with this solution, i get the brightes picture... i'm going to play with other reflectors and post my results ;-)
more pics you can see at www.edwas.de under "all i have" than "bauanleitung"
this is a german site with a german forum. hope to see you there
after i made an reflector with aluminiumfolie, my picture is much better:
*smile* ;-)
*smile* ;-)
that is only for testing... so don't laught ;-)
i have this from an kitchen-store:
now i took some aluminium folie (from my kitchen ;-)
and put the alu arround the figure:
now, put the dish away from the aluminium an you get following:
in my projektor it looks like this:
if i have the best solution, i buy some aluminiumfolie, that is not as thin as the kitchen alu and make my reflektor like you, gui_999 ;-)
cu soon ED
cu soon ED
THX much, but i think, it could work better ;-)
my lens is from an old OHP 60x60 mm (~ 2,4x2,4 inches) but i do not have any other informations. the distace between the lens and my fresnel is arround 25cm (~10 inches)
have you ever made a reflector, like you postet? i would like to see it not only on drawings ;-)
Well I bought a mixing bowl! Less trouble this way
http://www.epinions.com/Rosle_3_pc_Stainless_Steel_Deep_Mixing_Bowl_Set__Mixing_Bowls_15671
I'll try to put a spherical bowl in top of it so I can have the "almost" same shape I wanted. The only thing I don't know for now is what condenser I will use
I thing I should buy a cheap old OHP and take the condenser and projection lens out of it.
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- My Project ;-)
