Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 15th December 2008, 10:54 PM   #1
Default Epson Modded For Alternate Lamp Sources
This is my first time posting here. I have seen many refrences to here from lumenlab. I have some interesting projects in the works with Epson 3LCD projectors and alternate lamp sources.
The current model - Epson PowerLite 73c
The ballast was pretty easy to bypass after some poking around with a multimeter.
***For those of you that are having trouble bypassing the ballast on any projector***
1 - Find the group of wires that come from the ballast to the main board.
2 - Power the projector on with NO lamp.
3 - Measure the voltages on all the wires connecting to the main board.
4 - Find the wire that is close to +3V
5 - Insert lamp (If you have one) and power on. Measure the voltage of this wire again. The voltage should be around 0V
6 - Connect the spot on the board where that wire connected to a ground on the main board.
This will bypass the lamps for 90% of projectors. It has worked for me on about 8 different models.
Here are some pictures of the inside and of the wire added ot bypass the ballast.
More to come as I test new lamp sources. LED and HID will both be tried. HID worked well on a DLP that I modded.
Old 21st December 2008, 11:16 PM   #2
I'm very interested in seeing more pics. Thanks
Victor
Old 22nd December 2008, 04:06 AM   #3
I am currently looking into some HID auto lamp setups that will give close to 8000 lumens at the lamp. More to come after I get a lamp and ballast. Good news is the both of them should be under $120
Old 22nd December 2008, 08:14 AM   #4
Very cool. I have an Eiki LCX-990 that has a dead bulb which I'm very interested in modding.
Victor
Old 22nd December 2008, 08:42 AM   #5
Have you bypassed the ballast?
Old 22nd December 2008, 03:55 PM   #6
Not yet. I have to open it up first. Also, i'm pretty much a newb with multimeters so i might need you to walk me thru it
Victor
Old 22nd December 2008, 09:07 PM   #7
Open it up and take some pictures
Old 23rd December 2008, 05:11 PM   #8
I should have some pics after xmas- probably by the weekend
Thanks for helping out and merry xmas
Old 30th December 2008, 06:09 AM   #9
Just got myself a multimeter so I'll try to pop open the hood by next week
Victor
Old 14th January 2009, 06:09 AM   #10
Okay pictures-
Where to start??
Victor
Page generated in 0.15745 seconds (48.70% PHP - 51.30% MySQL) with 11 queries
