#21 |
To Luigi? It is most likely the lamp though it may be a bad ballast in the power supply. Pull the lamp & remove the glass from the front. There's a little wire hold down to remove then use a small flat blade screw driver to pull the glass. Give the cross bar a little twist, gently, at the top of the lamp in the center of the silver bar. If the lamp is bad it will crack immediately or if it has already cracked check inside the reflector for a small piece of glass. The lamps for the LP500/530 fail very often in this manner.
To all: REPLACEMENT LAMPS. You can get good ones for $42 JYS/DC 270 watt from YWH here on the forum. Put up a request & he'll give you instructions. Good Luck, Jim PS I buy all dead lamp modules for the LP500 & LP530 & SP110 Infocus models. Contact me at PRMHELP@earthlink.net if you have any to sell. |
#22 | |
Thanks for the response. |
#23 |
YWH only has the lamps that you have to rebuild & if you're using for a presentation I suggest you buy a new lamp instead as the rebuilds are not quite as bright as a new one & if you screw up while rebuilding you're in a bind.. You can get them on Ebay, from Infocus.com for $430 I think, or I have a few for $299 that are new, unused. If you want one from me let me know ASAP so it can get to your country in time. Thanks, Jim |
#24 | |
I've been searching around trying to find out what is entailed in the rebuild of a LP530 lamp. There is talk of fireplace cement and others mention that the bulb will screw into the old bracket. I would like to buy a bulb form YWH, but am trying to get a better picture of what I am getting into. On a separate note, I see the bulbs available on projectordoctor.com but there are two choices (one is Cobalt I think). How do I know which one I want, should I buy from them? Sorry for all of the noob questions. I just got my LP530 from work because it was flaky and they didn't want it anymore. Same problem as LuigiLuigi where the green light blinks and then turns amber after a while. Projector fires up again after being unplugged for many hours. Any help or direction is greatly appreciated. |
#25 |
Do not mean to bump a old thread but I have an infocus projector here that has a lamp issue. I have looked all over the net and even called infocus to get no help.
The issue is the lamp is not firing. Before I put in a new $400 lamp I wanted to check the voltage at the connector but can not find what the voltage should be when measured with the lamp removed. Can anyone here provide this info? Also if I find I need a new ballast for this unit where can I get one. |
#26 |
Hi childsid,
looking for the instructions you said you had posted to the forum concerning replacing the bulb in an LP500. Where are they? Looking at ordering a replacement bulb and want to know what to expect. Thanks -Mike |
| Need help with an lp530 | schauhan17 | Introductions | 4 | 24th November 2008 10:01 PM |
| need help with infocus lp530 | schauhan17 | Parts | 0 | 17th November 2008 02:01 PM |
| Electronic Lamps, electricity, i need help, lamps burning, needing procedure | destroyer X | Solid State | 27 | 13th September 2005 09:27 AM |
| Page generated in 0.08637 seconds (76.59% PHP - 23.41% MySQL) with 10 queries |
