Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 29th October 2007, 09:23 AM   #1
Default Help repairing Infocus LP530
Hi! ok I have been asked to start a new thread (in the Help with InFocus LP340 thread)so sorry for posting this again
I got a lamp from ywh it worked great the first day i testet it (bright and with good colours).But sadly the next day the projector broke down just after 30 minutes.After checking the powerboard the first thing i noticed was that the resistor R577 is burned (and open) and the condensator C518 is shorted.After some reading in this great forum I guess that the viper100a and one or two photocouplers SFH617A-2 is gone too and C13
(el.condensator 100mikroF. 25V).And the 3 pinned component on the left of C518 marked ?508 (i canīt read the first letter ).
I guess schematics for this powerboard is impossible to find.If i gonna try to repair this i need to know the values of the following:
R577 ??? ohms (canīt read the numbers because its burnt think it begins with a 5 and ends with a 0)
C518 ?? (got no markings)
?508 donīt know what this is transistor or diod ?? (itīs marked n5 JE)
Projector: Infocus LP530
Ballast: MagneTek Model: 3A49-03-100 (Output:75VDC @ 3.6A)Original lamp is: 270w SHP now lamp is 270w JYS/DC from ywh
Can you mbates14 or anybody here help me with this, or where i can find a new powerboard?
Any help would be great! Thanks a lot!
Old 29th October 2007, 11:49 AM   #2
i hate to burst ywh bubble, but his lamps just arnt compatible with these power supplies.
i dont know, and i dont care how many good successes there have been with 500s, and 530s, but ive got more 500 power supplies on my work bench that i have to repair, then you will EVER see, that tried his lamps. lol....
the LP530 supplies just dont have enough ignition voltage to fire them off, and will eventually cause the push-pull controller to fail...
the LP500s will cause an over-current condition and cause them to fail, such as in your case..
my next post will be how to fix the failed supplies.
to PREVENT this mess with ywh lamps for the most part:
there is a power level adjustment screw on the board. it needs to be turned up about an 8th of a turn. that should do it.
Old 23rd November 2007, 07:50 AM   #3
Send a message via MSN to Lex-LP350
Default Help with infocus LP350
Hi mbates14, I read your post about how to repair Viper100A failure on LP340B / LP350 porwer supply, I repair a couple of power supplyes following your guidelines but now one of them fail again, then searching for information I read that a new lamp is not compatible with this type of power supply because need some rework...
Then if I install a replacement lamp for an infocus LP350, I think the old lam/bulb is a LP-LAMP-LP3E, but according to www.infocus.com a replacement for the old LP-LAMP-LP3E
will be the LP-LAMP-LP3F but a rebuild of the projector is required
(power supply) to fit the new LP-LAMP-LP3F
Does anyone know why the projector has to be rebuild ?
(as far as I can see the new bulb is the same as the old, they are both labeled SHP6 on the bulb, but lamp module is labeled 505-0631-02 on the old module and 505-0631-05 on the new module.
Obviously a rebuild is need to prevent the Viper100A failure, I think, do any of you know how the rebuild is done ? or how to prevent the Viper100A to fail again ?
Thanks.
Old 23rd November 2007, 09:04 AM   #4
Default Other LP350...
Hi again mbates14, just received other LP350 for repair but it have a totally different failure: the resistors R530 and R532 are totally blown, also other parts like R538...
You know about this failure ? Can you provide me please guidelines to repair this power supply ?
Thanks again.
Old 23rd November 2007, 03:07 PM   #5
Default Re: Help with infocus LP350
Thanks.
no.. the rebuild is required to stop the boost converter from frying its windings and MOSFET, becuase of the different required current draws.
Old 23rd November 2007, 03:09 PM   #6
Thanks.
i dont like working on those goofy *** LP340/350 supplies becuase of the stupid silicone blobs. any suggestions with that???
Old 25th November 2007, 01:18 AM   #7
So mbates14 do have any clues for me on how to fix my projector?
for example this one?:?508 donīt know what this is transistor or diod ?? (itīs marked n5 JE)
Old 28th November 2007, 07:08 PM   #8
Default JE = BAV99
Hi Wombatten, the piece marked as JE corresponds to a Vishay dual diode BAV99, you can download the datasheet:
http://www.vishay.com/docs/85718/85718.pdf
You can use any BAV99 (SOT23 package) like fairchild or maybe ON semiconductor, but they are marked as A7, no problem is the same part:
http://www.fairchildsemi.com/ds/BA/BAV99.pdf
http://www.onsemi.com/pub/Collateral/BAV99LT1-D.PDF
Also, you can purchase them at:
http://www.newark.com
Old 29th November 2007, 04:40 PM   #9
Ok! thanks a lot for your help Lex-LP350
Old 8th January 2008, 10:13 AM   #10
Issydad is offline Issydad  United Kingdom
Default LP530 PSU rebuild/upgrade
Dear all,
reading this thread the upgrade/rebuild to the LP530 power supply necessary to allow it to drive the new 5F bulb is mentioned but not described.
I have an old LP530 which I want to modify to take the new bulbs (missed free infocus upgrade by 2 weeks!)
Electronic engineer so happy to solder on. Anyone able to describe the modifications necessary?
thanks in advance
need help with infocus lp530 schauhan17 Parts 0 17th November 2008 02:01 PM
Copyright Đ1999-2013 diyAudio
