Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 6th April 2003, 02:46 PM   #61
that was for side by side color comparison. I have a screen that I project onto, the big black thing in the corner is the screen in it's compartment. The only reason I had it projected like that was for color comparison.
Old 6th April 2003, 04:39 PM   #62
Negative Design's Avatar
Send a message via AIM to Negative Design Send a message via Yahoo to Negative Design
Originally posted by Mavmesa
Windows Media Player 9.
Not knowing the setup, I have no way to judge the quality or expectations of his system.
Ken
Thanks i just got it to work
**OFF TOPIC** what was your highest score on Crazy Taxi? when i had my DC mine was around 35,000 + i miss that game lol
Old 7th April 2003, 01:02 AM   #63
In the arcade (I work in an arcade, so I play it more often than never), I've gotten $43,000+ using the tricycle and BD Joe. At home, I usually get around $10,000. My girlfriend is the one with the scores on the high score list, though, cause I got the memory pack after we were going against eachother to see who could get the most money. I recently started playing again, but I'm not quite as good as I one was with the Dreamcast version. There's something about the cab turning in the opposite direction after I do too many Crazy Boosts in a row.
Old 8th April 2003, 01:32 AM   #64
kl899 is offline kl899  United States
Send a message via ICQ to kl899 Send a message via AIM to kl899
Here are some unoptimized pictures of my results from a borrowed camera that I didn't know how to work properly.. in real life the image quality is better and I hope to have better pictures this weekend.
Old 8th April 2003, 01:33 AM   #65
These pics are of Gladitor btw. Please see my seperate thread for more pics of my setup.
Old 13th April 2003, 09:54 AM   #66
Default Before I Spend The Bucks
Could someone please post a comparison shot of a dark scene/light scene using one of the monitors (NEC 1545V / NEC 1550V / Philips 105B / ect) with a 300:1 contrast ratio? Right now I am using a LCD projection panel and that is the only spec that I am not happy with and I am trying to determine a head of time if I will be satisfied with a 300:1 ratio. Please try for the best pictures possible (ie. true to life quality) but do show a true comparison between the dark and light scenes...Thanks in advance!!
"Common Sense is the least common sense of them all."
Old 19th April 2003, 12:20 AM   #67
proto5 is offline proto5  United States
Default New screenshot- new idea
Guys:
This was with the Elmo fresnels separated and the upper one moved ON TOP of the LCD. Better use of panel size and better edge to edge brightness. Note the nice crisp colors? That's component video for you. This is 85" diagonal on a WINDOW SHADE!
NEC 1545
ELMO SD305
9A62 component video-VGA adapter (WELL WORTH THE $$$)
Old 19th April 2003, 02:18 PM   #68
karrock is offline karrock  United States
Wowsers Proto!! Simply bea-u-tiful picture!
Any plans for building an enclosed projector box instead of the overhead?
How hard was the 1545 to find?
~Tony
Old 19th April 2003, 03:12 PM   #69
Default 1545v
Bought the 1545 on Ebay for around $270. Will build box after all the bugs are worked out.
thanks!
Old 19th April 2003, 03:33 PM   #70
water1 is offline water1  United States
Elmo fresnels separated ?
You can take it apart ? Separate it into 2 pices ?
Page generated in 0.10414 seconds (77.71% PHP - 22.29% MySQL) with 11 queries
