My project
this is one of my projects that i build for someone .
The forst 4 screenshots are in full daylight onjust a simple wall.
The last three are in the customers home on a curtain .
Everything in between is in the dark at my home again.
The lcd is a broken one in the first pics that i always use for building .You can see it in the left upper corner.
Special thanks to my friend Carpow who made this build posible.
http://www.dity.nl/forum/afgeronde-projectors/3150-15-4-inch-wuxga-pro-lens-beamer.html
Re: My project
Nice job on the projector, very nice bright screen shots!! what bulb, fresnel combo did you use? 500mm Triplet? 550mm field fresnel? 400w MH bulb? any inside shots of the projector? Heres a pic of one I built for a customer. I have lots more pics on my homepage.
pieterbas said:this is one of my projects that i build for someone .
100mm cold mirror
400 watt hqi-ts
i use a cecla ballast for my lamp this one is 4.6 ampere gives much more licht .
no condensor
ir /uv filter glas .
220mm fresnel groove pitch 0.5
630mm fresnel groove pitch 0.5
500mm triplet .
inside shots :
http://www.dity.nl/forum/projector-dagboek/2954-15-4-wuxga-450mm-varifocus-beamer.html
i know your website i know you from lumenlab .
400 watt hqi-ts
no condensor
500mm triplet .
inside shots :
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- Post Your Results II
