Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Thread Tools
Old 19th February 2003, 10:11 AM   #11
heres a pic of my setup... I modified the top of the overhead, and enlarged the whole to expose the whole fresnel. and Im just using a piece of glass to hold the lcd and the rest of the components on the other side, all I really did is remove the metal part that holds the panel in place and flip it open like a book, very easy.
Old 19th February 2003, 11:59 AM   #12
water1 is offline water1
Goldmoth, Is this your monitor?
http://www.sstcomputer.com/product.asp?pf_id=LCD-A15V
Just want to make sure this is the right one......
Old 19th February 2003, 08:18 PM   #13
yep thats it...
Old 19th February 2003, 08:36 PM   #14
Thank's Goldmoth,
So it's easy to take apart?
Old 19th February 2003, 11:33 PM   #15
yeah all your really have to do is take the plastic outer case off, then pry the little tabs open to get the metal from around the screen. of course you have to be really careful. and pull off the sticky aluminized paper shielding off the back. But I wouldn't say any of it was hard to do.. all of the components on the board stay in the same place, this makes the whole setup more stable, just unplug the CCFLs. just be careful when pulling the panel up, " when you open the book". I really cant think of an easier way to describe it than to say it iis like a book. hope that helps..
Old 19th February 2003, 11:47 PM   #16
OK I think this is my last "?"
What is a CCFLs ? "just unplug the CCFLs"?
Also did you have to ground anything ? I know people useing the 1545v had to ground one spot.
Old 20th February 2003, 04:37 AM   #17
CCFLs are the backlights, 2 of them.... and nope there are no grounds to worry about...
Old 20th February 2003, 04:47 AM   #18
Thank's for the help Goldmoth,
All the info. help's. Thank's
Old 23rd February 2003, 02:44 AM   #19
ajc999 is offline ajc999
Default Video Capture of Results
Click on this link http://home.hawaii.rr.com/microman/
There is a clip of my results of my setup from the movie Saving Private Ryan. For some reason I couldn't get my digital camera to take a good picture. The clip is also only 320*240 but it gives a good impression of brightness and contrast. The room was as dark as I could get it.
My setup:
LCD Panel - Ovation 822C -640*480, 2M Colors
Overhead Projector - Apollo Concept 2200 - 4000 Lumens
Screen - Dalite Matt White 70"x70"
PS2 attached to panel using Svideo input.
I don't have the VGA cable yet so I'm not sure if I'll get better results using a PC DVD player. I do notice that if I look closely I can see vertical scan lines. But it is not bad. Anyone notice a difference using Svideo vs PC Vga when watching DVD? Overall I'd say the picture is pretty decent.
Old 25th February 2003, 06:47 AM   #20
Here are some pics of my Dukane 4000 / Nview Z215 / Da-lite 96x72 combo. I was thinking I'd have to sell my setup on ebay, so I took these pics the other day. Having just found out that my panel does 848x480 compressed, I am sad that it might have to go...
Also, I really think this is the best panel I've seen for playing console games on, even better than a Sharp qa-1750. It definetly blows the !@#% out of a Qa-1650! Sharp panels seem to have a brightness gradiation that goes from darker to lighter as you go up the panel, wheras this panel does not. This is even evident on the Qa-2500.
Thread Tools
Page generated in 0.10172009 seconds (74.07% PHP - 25.93% MySQL) with 11 queries
Copyright ©1999-2010 diyAudio
