| DIY HiFi Supply Parts and Kits from Diy HiFi Supply |
Hi Thorsten,
Is the Lady Day 91 or a "simple 300B SE" powerful enough to drive the SV 215 SB full-range driver (8 ohm, 35W RMS) on an open baffle in an active system crossed-over to two 15" OB woofers at 120-140 Hz? The room is realtively small (200 sq ft / 2500 cu ft) and the music is mostly West Coast (AOR, melodic soft rock) but also modern pop/dance and rock. Listening at relatively loud (studio) SPL levels. If not, would the Lux 91 Max monos do the trick (although they are border-line on what I would like to spend, including a decent set of valves and postage to the UK). If none of the above cuts it in this application, should I be looking at 845 SE or something else (300 PSE or PP, 805, 211, 813, GM70)? Or should I just stick to my PrimaLuna Prologue II (4 x KT88 @ 2 x 44W) and give up all hopes of injecting a dose of SET magic into this particular setup. Cheers, Nick |
| Supravox 215 Signature Bicone Full Range Drivers | abpea | Swap Meet | 8 | 19th August 2008 11:26 PM |
| Supravox 215RTF Bicone | felixx | Full Range | 18 | 29th June 2006 01:01 AM |
| Supravox 215 Signature Bicone | Angel Puerto | Full Range | 3 | 24th July 2005 03:03 AM |
| supravox 215 bicone | JamesD | Full Range | 5 | 29th April 2005 02:02 AM |
| Supravox 215 Signature Bicone build quality | zygibajt | Multi-Way | 4 | 4th January 2004 01:35 PM |
