| DIY HiFi Supply Parts and Kits from Diy HiFi Supply |
#11 |
Hi Thorsten (or others in the know...),
I found this nice old RCA black plate 5R4GY rectifier tube and wonder if this can be used as rectifier in the TRAM II? Based on info I have been able to find on the Internet the main difference to the 5U4 seems to be a slightly different voltage drop across the diodes in the tubes, but I suppose this can be corrected with a simple adjustment of the CCS?
#12 |
At least this RCA 5R4GY seems to send out less hum than other rectifiers, so for now I will continue to use it. The level of hum is a bit lower than with the Svetlana I normally use. The rectifiers I have tried so far are: Valve Art 274 (with some triodes, there is quite a lot of hum with this one). NOS Svetlana 5U3C (Highly recommended for less hum than the VA 274). I should mention, that I don't have hum with all the tubes, just some of the NOS tubes. The dilemma is, that IMHO the NOS RCA 2A3 are the best sounding tubes I have tried, but they also seem to pick up more hum, so I'm searching for the most quiet rectifiers to use with the RCA triodes... |
| TRAM2 Remote Code for Logitech Harmony | jacklee | DIY HiFi Supply | 3 | 4th October 2011 04:48 PM |
| GZ33 in place of 5U4 can it be done? | mario13 | Tubes / Valves | 3 | 18th May 2011 01:08 PM |
| sputtering 5u4 on diy Wheatfield amp | hansel67 | Tubes / Valves | 14 | 22nd July 2010 12:07 AM |
| Futterman style 6AS7 OTL with other tubes | Brit01 | Tubes / Valves | 39 | 22nd July 2009 05:04 PM |
| 5AS4 sub for 5U4 | gingertube | Tubes / Valves | 6 | 10th March 2005 08:35 AM |
| Page generated in 0.09524 seconds (60.40% PHP - 39.60% MySQL) with 10 queries |
