| DIY HiFi Supply Parts and Kits from Diy HiFi Supply |
#31 | |
Cheers
...is I disappear. There is ONLY the music. |
#32 |
Hi there,
I have the luck to be in HK recently. I listened to the speakers and I am still very pleased with the sound I heard. The only issue for me is the cabinet, I do not like the current material and finish, it is not in line with the sound the speaker gives. Is there someone who has an example of a nice cabinet with this speaker combination? It would be nice to get some inspiration. |
#33 | |
Previously: Kuei Yang Wang
There are no limits to ingenuity regarding the way the cabinets may be made and the materials they can be made from. When my laptop was nicked a few weeks I lost the drawings I had made for a set of stone enclosure sets for the Crescendo Grande that where to be made from Indian "Black Galaxy Granite": ![]() The basic design was borrowed somewhat from the YG Acoustics Kipod/Studio", but with more or less inverted colour scheme: ![]() Now of course I have to re-do all the drawings. Does anyone happen to have a recommendation for a very easy to use/learn drawing program that can produce 3D Renders with surface options, output 2D technical drawings with measurements and easily create exploded assembly drawings? Ciao T |
#34 |
Cost?
#35 |
It would likely be several 1000 Euro (still working on the pricing) plus shipping several 100Kg from Hong Kong. It is really only viable for local clients. You can have a look around for a local shop in Toronto that works with stone. I will make the plans available once everything done. The top section will be basically precisely the Crescendo as per plans, the Woofer section will mainly be re-shaped. Oh and of course 25mm Stone instead of 18mm Plywood. The woofer section can be shaped very freely as long net volume (without port) and port length and crossection are observed. Ciao T |
#36 |
Is there still a chance for the youtube video on crescendos in action?
#37 | |
#38 | |
I think Google Sketchup: Google SketchUp is easy enough to learn fast, but I don't know if it fulfills all your demands Use tutorial videos... it saves time. Best, Ivica
#39 |
bump. just curious to see if anyone have built those?
I plan on building those later this year but would love to know what people thinks of the performance... |
#40 |
Goodness those ribbons are large!
I bet these are incredible sounding. |
| Denon DP-30L turntable problem | FSHZ:42 | Analogue Source | 2 | 20th March 2008 11:29 AM |
| Eureka pre re-cap | impsick | Instruments and Amps | 0 | 24th February 2007 01:21 AM |
| boosting frequencies from 45-65hz | qguy | Multi-Way | 11 | 8th November 2006 11:02 PM |
| Making a highly efficent ESL for play from 1khz-25khz | Audiophilenoob | Planars & Exotics | 23 | 5th June 2005 02:12 AM |
| Eureka! | johngalt47 | Chip Amps | 4 | 30th November 2004 11:27 AM |
| Page generated in 0.12527 seconds (81.56% PHP - 18.44% MySQL) with 11 queries |
