Go Back   Home > Forums > > >
DIY HiFi Supply Parts and Kits from Diy HiFi Supply
Old 10th November 2013, 08:33 AM   #921
rab28 is offline rab28  Australia
Originally Posted by rab28 View Post
However, the motivation for this post is that, when no music is playing, i can now hear a low level oscillation/feedback type whine that appears occasionally
Hi all, just a quick update to say that i have determined that the 'oscillation' noise in my Tram2 is the (Coleman regulator) cooling fans kicking in.
At this stage I am not sure whether its caused by EM radiation from the fan supply wires, or from the fans themselves, or noise injected back down to the supply from the fan motors (maybe the most likely?). I suppose the easiest first step is to try to shield the supply wires and see if that makes any difference.
Incidentally, my friend's Tram2 that does not have this problem has (cooling) holes drilled through the top of the chassis in addition to the fans: I wonder if the holes might be enough to stop the fan from coming on?
I note that my fans only stay on for something like 20-30 seconds... I suppose a possible work around might be to test the actual temperature of the regs at equilibrium and see if can avoid the fans kicking in at all during normal operation!
- richard
Old 10th November 2013, 08:46 AM   #922
Desmo is offline Desmo  Denmark
I would guess, that it's mechanical vibration from the fans. Try to have the fans running without mechanical contact, if that solves the problem you need better mechanical / vibration isolation in the way you mount them.
Regards, Morten
Old 10th November 2013, 09:03 AM   #923
Thanks Morten, i bet you are correct: the character of the noise does seem consistent with vibration of the tube components!
Also, i had never noticed the noise until I started using an EML rectifier tube, so maybe it's vibration of only that rectifier tube that's causing the noise...!
- richard
Old 10th November 2013, 10:18 AM   #924
kazap is offline kazap  Australia
kazap's Avatar
I used a fan under my Tram2 in the heat of last summer with early stock regulators. But the fan was powered on all the time, was powered with a linear 5v low noise supply plugged into a different outlet form the preamp, was a very low noise 12V design, had special bearings and was mounted via silicon to isolate direct vibration. It was noise free via the speakers and from 40cm away.
I think the airflow from drilling extra holes to get cooling via passive convection could be optimised using a chimney effect. The top transformer cover gets warm enough to likely augment updraught by attaching copper tubes with thermal paste around the back of the transformer cover.
Old 10th November 2013, 10:19 AM   #925
Rod Coleman is offline Rod Coleman  United Kingdom
работник
Rod Coleman's Avatar
DHT OTL Linestage - Tram 2
Bob Magaletta [Magz] has done some work on quiet fans - maybe will help:
http://www.diyaudio.com/forums/tubes...ml#post3686065
Old 10th November 2013, 05:31 PM   #926
montesquieu61 is offline montesquieu61  United Kingdom
Coming very late to this thread but hope someone here can help ....I've picked up a Tram2 (already built) ...
However it has no remote and I have no idea what remote I should buy to work with it.
Any suggestions on a simple remote to operate it? (ideal would be just with input selection and volume control but any remote at all really would be great).
If anyone has a pointer to something in particular (say on Amazon or eBay) that would be ideal.
I'm actually pretty short of remotes in here, I don't have a TV or DVD player any more (haven't had for years) so the only remote in operation is the one for the CD transport.
Old 10th November 2013, 06:10 PM   #927
beardman is offline beardman  Denmark
I use a Maranz RC 1400
it is a universal remote...when i use the tape selection it works on the volume--
here is a link to the manual---on the last pages there is something about the remote
http://www.diyhifisupply.com/files/Tram2R1.36.pdf
Old 11th November 2013, 09:46 AM   #928
Thanks Rod: i'll check it out!
Easy, as noted above, any universal remote should work (i use a Logitech Harmony 1). For codes, also see this thread: TRAM2 Remote Code for Logitech Harmony [EDIT: ah, i just noticed you already posted on that thread...]
Finally, diyaudiosupply probably still have the $20 remotes that they supply with the Tram. You could try contacting Simon. I seem to recall you can also buy them on eBay, but it would be easier to buy one from Simon, pre-programmed.
- r.
Old 25th November 2013, 11:00 PM   #929
PixelPlay is offline PixelPlay  Australia
Well.....Finally I have my very own Tram. At the moment it is a 2 box affair with separate transformers for the B+ and heaters etc. Thankfully I have no hum (my biggest worry). I was picking up some mechanical noise from the fans however I have now devised a way to keep them isolated.
I have, with the help of the generous posts of members in this forum implemented the following:
TJ 2A3 SE output tubes (thanks Morten )
Chatham 5998 Mu (others on order)
Emission Labs 5U4G
Coleman regs with Mortens upgrades (thanks Morten )
Duelund CAST input caps (thanks Morten )
Obligato 2.2 X6 output caps (thanks Morten )
SHINKOH Resistors throughout (thanks Morten )
I could feel my heart in my throat and my stomach turning on first connected turn on and initially the left channel was out........ I traced it down to a faulty resistor in shunt mode. All fixed and sounding wonderful. Now for the burn in.
Thank you again
Greg
"Live each day as if it is your last"
Old 17th December 2013, 07:57 PM   #930
Falck is offline Falck  Sweden
Default Headphones - Tram mk2 question
Pardon my limited knowledge, but is it possible to use Headphones, Sennheiser HD 650 (impedance 300 ohm), directly from the Tram mk2 output? If not, does anyone have a suggestion of a modification, external converter etc. Do I need a separate headphone amp?
Regards, Mats Falck
DHT OTL Linestage - Tram 2Hide this!Advertise here!
C3M linestage costa23 Tubes / Valves 15 23rd August 2009 08:53 AM
C3m linestage bequerel Tubes / Valves 32 14th April 2009 06:03 AM
48V B+ linestage hirafu_boarder Tubes / Valves 24 11th May 2008 05:57 PM
Another linestage...... kianbach Tubes / Valves 11 28th June 2005 05:34 PM
:: linestage [Bryston B60] :: dhengkoel Solid State 6 26th September 2002 03:32 PM
