Go Back   Home > Forums > > >
DIY HiFi Supply Parts and Kits from Diy HiFi Supply
Old 9th December 2010, 03:21 PM   #61
beardman is offline beardman  Denmark
I can see that none off you have noise and hum--
i cant use mine 45tj witout mine irontube----way too much hum--
i have also some noise--must play musik to forget it---i use the --6db output--
is this what you call tube noise ?
i can hear the noise on 6 meter distance---
what about you--?
Bjarne
Old 9th December 2010, 05:21 PM   #62
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
Originally Posted by catastrofe View Post
Is it possible to use a Sophia 274 in place of the 5U4?
In principle - yes.
The Tram II does use more than 10uF input capacitance though and it draws around 70mA current.
Ciao T
Old 9th December 2010, 05:29 PM   #63
catastrofe is offline catastrofe  United States
Originally Posted by ThorstenL View Post
In principle - yes.
Ciao T
Sounds like sticking with a 5U4 is the way to go. . .
Old 10th December 2010, 09:15 AM   #64
There is no "-6dB" Output on the Tram, only +6dB (the others are -3dB and -12dB).
If you use the +6dB Output you need to have very low gain amplifiers (for example common solid state power amplifiers with 26dB Gain) and low efficiency speakers.
The moving light dot on the volume control for slightly elevated (somewhat loud, but not extreme) should be at least at around 11 - 1 O'Clock but can be as high as 2 - 3 O'Clock.
In this case you have the right output for your overall system gain.
If your volume control setting is much lower than this for normal listening you are likely to have noise problems, so try using a lower output.
The lower outputs attenuate noise and signal equally, however you normally have plenty of volume control range in reserve to simply turn the signal back up, and the noise remains lowered.
Ciao T
Old 10th December 2010, 12:41 PM   #65
Thanks Thorstenl
my fault---i use the --3db
can hear much lower noise with the --12db but it is not loud ennough--
so i think everything is alright---
the hum is still a mystery----can not use the pre without my iron tube for shield, and a wire to the input ground---(no hum then )
Old 10th December 2010, 03:35 PM   #66
Certain Signal Tubes are better than others at pulling hum signals out of the air, some rectifiers are better putting it into the Air. Ironically the quietest Tubes seem to be Shugang 2A3B (Single Anode version).
Ciao T
Old 14th December 2010, 11:07 AM   #67
Mihan is offline Mihan  New Zealand
I would be interested to know what power amps people are using with the Tram 2.
I note that Clive Meakins is using a pair of single ended LD 91's.
Would this linestage be overkill or indeed suitable with EL34/KT88 etc push pull power amps?
Are people mainly using analog or digital sources into the Tram?
Old 14th December 2010, 11:50 AM   #68
clivetjm is offline clivetjm  United Kingdom
I tried Tram into what you might call a traditional solidstate system, the quality of the Tram shone through, I have no doubt that a tube PP would be a great match.
I use PC audio into a DAC as well as analogue. Again Tram delivers.
Old 14th December 2010, 11:55 AM   #69
Desmo is offline Desmo  Denmark
I have not recieved my Tram 2 yet (it's on it's way from HK), but I will use it in a system with both digital and analog front end, and with a Plinius SA-REF amp...
Old 15th December 2010, 07:41 AM   #70
I use my tram 2 with only digital--amp is a Gryphon Encore
DHT OTL Linestage - Tram 2Hide this!Advertise here!
C3M linestage costa23 Tubes / Valves 15 23rd August 2009 08:53 AM
C3m linestage bequerel Tubes / Valves 32 14th April 2009 06:03 AM
48V B+ linestage hirafu_boarder Tubes / Valves 24 11th May 2008 05:57 PM
Another linestage...... kianbach Tubes / Valves 11 28th June 2005 05:34 PM
:: linestage [Bryston B60] :: dhengkoel Solid State 6 26th September 2002 03:32 PM
