DHT OTL Linestage - Tram 2 - Page 58 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > DIY HiFi Supply
DIY HiFi Supply Parts and Kits from Diy HiFi Supply
Old 5th February 2013, 08:47 AM   #571
rab28 is offline rab28  Australia
Originally Posted by marybety View Post
My Tram MK2 for SALE in Germany.
PM sent!
Old 6th February 2013, 08:49 AM   #572
kazap is offline kazap  Australia
kazap's Avatar
Default Tram2 headphone amplifier mod?
I suspect that with the correct output transformer, connected perhaps to the +6dB RCA outputs, that the Tram2 would make an incredible headamp.
Is this possible?
If it sounded like the DNA Stratus it would be stunning.
Old 10th February 2013, 09:33 AM   #573
Desmo is offline Desmo  Denmark
Slightly off topic, but just wanted to share, that I now have an all tube system... The Plinius SA-REF is gone and a pair of conrad-johnson LP275M mono blocks has found their way into my system...
The previous owner did not vacuum clean them before shipping, so I had an excuse to take off all the covers and clean the beasts Here are some pics of the internals, c-j does not skimp on part quality in their top-of-line amps: NO electrolytics in the power supply, everything is polypropylene and polystyrene caps... In the audio circuits they use their own teflon caps... Resistors in critical places are Vishay bulk foil... RCA and speaker connectors and most of the wiring is from Cardas etc etc...
Time for tube rolling the input tubes..! Right now I have a nice pair of Telefunken ECC88 from 1964 installed...
EDIT... Sorry, no pictures for now of the c-j's... After photobucket made changes to their site I can't get the upload of pictures to work anymore ...!? Anyone of you use photobucket? How do you do it with their new site!?
Regards, Morten
Old 10th February 2013, 10:23 AM   #574
diyAudio Moderator Emeritus
Bas Horneman's Avatar
You can upload them with our very own forum. Click on advanced or something and add the attachements
Verstuurd van mijn GT-N7000 met Tapatalk
Old 10th February 2013, 11:01 AM   #575
Ahh... I never noticed that feature... Thanks OK; so here are some pics of a pair of nice conrad-johnson tube amps. I was a bit concerned about their gain structure, but it's perfect with the Tram II (still use the middle of the 3 outputs as I did before).
Regards, Morten
Old 10th February 2013, 01:32 PM   #576
Love the turntable.
Old 11th February 2013, 05:37 PM   #577
Need help....my Tram2 make high pulses when the power get off
what can i do to stop this....use a relay or what ???????
and to Morten....great amp you got there
Bjarne
Old 11th February 2013, 05:42 PM   #578
Turn off your amp before you turn off the preamp... This is what I do.
Regards, Morten
Old 11th February 2013, 07:00 PM   #579
yes i normally do that...but sometime i make mistakes..not so good..need a safe solution
Old 11th February 2013, 07:13 PM   #580
Well, you have two options The best one: Stop making mistakes... Or the one that involves a relay in your signal path: Install a relay module that is connected to the mains with it's own little power supply, so that when the mains is connected the replay is closed, and instantly when the mains voltage is gone the replay opens. You can also install the relay so it shorts the output to ground when the mains voltage is switched off, but I don't know if the tubes can handle this. Maybe it's OK because the tube only see the short for a few seconds until the voltages are gone from the tube...
Maybe someone has installed some kind of relay module..!?
Regards, Morten
C3M linestage costa23 Tubes / Valves 15 23rd August 2009 09:53 AM
C3m linestage bequerel Tubes / Valves 32 14th April 2009 07:03 AM
48V B+ linestage hirafu_boarder Tubes / Valves 24 11th May 2008 06:57 PM
Another linestage...... kianbach Tubes / Valves 11 28th June 2005 06:34 PM
:: linestage [Bryston B60] :: dhengkoel Solid State 6 26th September 2002 04:32 PM
Copyright 1999-2017 diyAudio
