#561 |
For some reason it's not easy to get the message across, everyone seems to focus on the noise performance only. So I will continue to repeat myself on this:
The sonic improvement with the Rod Coleman DHT regulators is bigger than any other upgrade I have made on my Tram II, including the Full Music 2A3 SE tubes. I even think the sonic improvement with the Rod Coleman regulators is bigger than all the other upgrades combined, especially if the small upgrade with a cap+resistor on the regulator module is made. The better noise performance is just a bonus...
Regards, Morten |
#562 |
Message received. Coleman regulator order is going in now. Thanks.
#563 |
Hej Morten
Must try the fixed resistor tips....mine Tram drift a lot like yours,, Thanks Bjarne |
#564 |
Hey Bjarne,
It's an easy small modification to do, you just have to get the value of the resistor very precise to get the anode voltage right... Or do like I mention with a 10 ohm multiturn trimmer and a fixed resistor in series...
Regards, Morten |
#565 |
Hej Morten--
at first i will try with the fixed resistor--try to do it in the evening best Bjarne |
#566 |
ufff no resistor in my stock..must buy some ..
not only the noise,but also the sound get better ,when the proper adjustment is made Bjarne |
#567 |
You better buy several values Bjarne, with the fixed resistor arrangement you have to get the value VERY accurate... So get some different values, also for some parallel couplings, for instance like I have 82 ohm // 2K2 in one channel...
Yes, the sound is clearly better when the anode voltage is ''in the zone'' than when it has drifted too low...
Regards, Morten |
#568 |
Thanks Morten...
do you use some resistor with low temp. drift ?low ppm i will order a 10ohm pot also Best Bjarne |
#569 |
I used standard 1% metal film resistors that I had in my resistor box...
Cheers, Morten
Regards, Morten |
#570 |
My Tram MK2 for SALE in Germany. Assembled and working.
I think I can save time and words about the sound descriptions. Pictures and Price only to private email addresses. I will include a pair of (not assembled) Rod Coleman regulators. I am moving and need to sell my whole rig. Offer and buy with confidence I have recently sold my Hypex NC400 amps through this very website. I have as well positive marks in Audiomarkt and Ebay. |
| Thread Tools | Search this Thread |
| C3M linestage | costa23 | Tubes / Valves | 15 | 23rd August 2009 08:53 AM |
| C3m linestage | bequerel | Tubes / Valves | 32 | 14th April 2009 06:03 AM |
| 48V B+ linestage | hirafu_boarder | Tubes / Valves | 24 | 11th May 2008 05:57 PM |
| Another linestage...... | kianbach | Tubes / Valves | 11 | 28th June 2005 05:34 PM |
| :: linestage [Bryston B60] :: | dhengkoel | Solid State | 6 | 26th September 2002 03:32 PM |
