DHT OTL Linestage - Tram 2 - Page 54 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > DIY HiFi Supply
DIY HiFi Supply Parts and Kits from Diy HiFi Supply
Old 5th January 2013, 09:10 PM   #531
Desmo is offline Desmo  Denmark
Interesting, how much are those rectifiers? And du you sell them?
Regards, Morten
Old 6th January 2013, 12:04 AM   #532
Morten, I do not sell them. The person (Craig Connor) I auditioned my equipment with, has them for his Killerdac. It's an exotic mix of NOS tubes, chokes, Deuland caps and Philips made in Holland TDA1541A crown or double crown chips. Click the image to open in full size. Craig purchased his on e-bay, but you can get them from Natubes in Vietnam. In the UK check out: Mullard Magic. Mullard, GEC, rectifier, Osram, 5U4G, Octal, Brimar, Williamson, CV575, CV1071, CV1575, GZ31, VU71, U52,
Craig has listened to alot of U52 tubes and he indicated not to touch the dark base U52 tubes. Only go for the U52 brown base with a single D getter. See picture: http://natubes.com/data/images/product/large_331.gif.
Peter
Old 6th January 2013, 01:07 AM   #533
56oval is offline 56oval  Australia
Originally Posted by ptashton View Post
Hugh, then you would not see the heater elements of the tubes at night. That is hypotonic to the eyes. It's like watching a fire. See the picture of my STC 4212E tube. I have had metal shielding in my Ah! CD player and I could not hear a difference. If the Full Music 2A3/SE are microphonic, then use the Herbie's Audio Lab Damping Instruments Guitar type dampners. The Full Music 45 ST shaped tubes are somewhat microphonic and I used the dampners with little difference in the noise heard.
From the review above: I'll put it simply; if you care about your music you must strongly consider this preamp. Don't let the potential need for fettling put you off but I appreciate that it won't suit some folks. As you can tell I'm over the moon with Tram Mk2, there's no way it's leaving my system.
Peter
Hello Peter
Nice amp I heard it at Lucas's .
Just before Chrissy I was at Lucas's and it looks like he'll be making reg boards for the Tram pre ,he's done a bit of work on them lately .
Cheers
Mal
Old 6th January 2013, 04:17 AM   #534
Hi Mal, when I was down at Melbourne, I lived at Hoppers Crossing and Wyndham Vale when I was in the RAAF at Point Cook.
The amps sound alot better with different coupling caps (SCR Teflon) and resistors (Philips close tolerence carbon 3 Watt). I changed the NOS Genelex KT88 to NOS GEC TT21. A KT88 with a Top cap. I also changed the 12AU7 to a Mullard E80CC. Both a big step forward.
Do you have a Tram 2 pre-amp. What is Lucas doing to the Tram 2 pre-amps???
Peter
Old 6th January 2013, 07:18 AM   #535
Peter
Hi Peter
I'm not far from Point Cook RAAF base .Glad to hear the changes to the amps
were positive .
I don't have a Tram2 ,my pre is one of Lucas's circuits .He's repaired a couple
and a few mods . Best get incontact with him ,he's always has something up his sleave .
Cheers
Mal
Old 6th January 2013, 07:52 AM   #536
Mal, when I spoke to Lucas, he said he was repairing broken Tram2 pre-amps. I had a incorrectly indicating bias module and DIYHIFI replaced it. The pre-amp worked, all the voltages were correct, but I was getting an incoorect bias red LED indication. No problems since then. It is quite a hardy pre-amp. It is built extremely well.
Is your pre-amp the 417A circuit.
Peter
Old 6th January 2013, 10:41 AM   #537
Peter
Similar ,I'm using the 6H30pi per channel with dual mono 5V4 rec power supplies 2 chassis job.I've had this combo for 10 years tme to update it with reg filiment supplies and Lucas's volume relay attenuator with IR control a new project he's doing this year.My whole system is BlackArt custom circuits from front end to amps and xovers .Active tube base system .
Anyway way off topic now .
Cheers
Mal
Old 7th January 2013, 07:39 AM   #538
@Peter... Thanks for the update on the NOS rectifier tubes, I must say that it's a jungle figuring out what is recommended and what is not - and those tubes are quite expensive..!
I have not done a lot of testing with different rectifiers, in the beginning when I got the Tram I just selected the rectifier tube, that would result in less hum. This was when I just got the Tram II and thought the right way to go was NOS triodes. I struggled with those NOS RCA 2A3 tubes where there was always hum and/or microphonics. With those the RCA 5R4GY was the most quiete, so basically I have used it because of that.
With my new production tubes: The Treasure 2A3-Z and the Full Music 2A3/SE there is no hum with any of the rectifiers. I just installed the Valve Art 274 again yesterday, it was the one where there was the most hum with the RCA's, but it's dead quiet with the Full Musics... Maybe it's time to actually try and listen to the sound, not the hum, if I can detect differences between the rectifiers I have.
If upgrading to expensive rectifier I would be tempted by the TJ / Full Music 274, based on my good experience with their triodes. Anyone know if mesh plate will be a problem in the rectifer? It can't be used in the triodes due to microphonics..
These are the rectifiers I have for now:
RCA brown base 5R4GY
Valve Art 274
NOS Svetlana 5U3C
Regards, Morten
Old 7th January 2013, 08:06 AM   #539
Morten, I too have tried the RCA brown base 5R4GY and Chatham Elec 5R4WGY. They did not do anything for me with regards to the sound of the Tram2. I did not detect any noise change compared to the Roger 5U4 ST glass tube that I settled on. But when I put in the GEC U52 bottom side 'D' getter tube it was like night and day. It was that dramatic.
To all, if you or if you have a friend that can lend you a GEC or Osram or Marconi or Cossor or Mullard or Brimar or MWT U52 Brown base muddy black plate rectifier tube with a bottom side 'D' getter, definitely remove the other rectifier that you have in place and install this wonderful tube. It will change your life and you will not take it out. Period.
Peter
Old 7th January 2013, 09:06 AM   #540
OK, I better buy two of them then..! Thanks for the tip, since the Tram II sounds so damn good it's worth the investment...
Regards, Morten
C3M linestage costa23 Tubes / Valves 15 23rd August 2009 08:53 AM
C3m linestage bequerel Tubes / Valves 32 14th April 2009 06:03 AM
48V B+ linestage hirafu_boarder Tubes / Valves 24 11th May 2008 05:57 PM
Another linestage...... kianbach Tubes / Valves 11 28th June 2005 05:34 PM
:: linestage [Bryston B60] :: dhengkoel Solid State 6 26th September 2002 03:32 PM
Copyright 1999-2017 diyAudio
