Go Back   Home > Forums > > >
DIY HiFi Supply Parts and Kits from Diy HiFi Supply
Old 2nd January 2013, 05:47 PM   #521
Desmo is offline Desmo  Denmark
Originally Posted by beardman View Post
Hmmmm i am 100 procent shure that i have ask ,about the inverting to Diy Hifisupply..in the mail they write that the Tram don't invert the phase
Bjarne
happy New year
Hi Bjarne,
As Thorsten mentioned in the post Hugh refers to: The Tram II inverts polarity..! This is a fact since all tube circuits with just one amplifying stage inverts polarity... I have also measured the polarity, and the Tram II does invert polarity.
They should make this more clear in the manual so users are aware that the must swap the speaker cables for the best sound...
Regards, Morten
Old 2nd January 2013, 05:50 PM   #522
Originally Posted by kazap View Post
Would you recommend I make tube chimneys from:
1. Steel pipe with thick walls
2. Copper Pipe
3. Copper sheet 1MM think that can be hand crafted to fit:
I would recommend not making any at all
Regards, Morten
Old 2nd January 2013, 11:55 PM   #523
ptashton is offline ptashton  Australia
Morten, you are absolutely correct. Correctly length and placed interconnect, power and speakers cables will elliminate interferences. Hugh, you need to get longer interconnect cables and not stack your equipment. Only have the equipment you are using on your audio stand. The other dac's, pre-amp all have magnetic fields from their own transformers which can interfere . Keep things mininal. Yesterday, we had power and interconnect cables very close to the tubes and there was no audible noise at the speakers except tube hiss which has always been present with the Tram2 with the DIYHIFI heater regulators. This hiss is very minimal.
You should just get your Tram2 built and later on see if you need shielding. Have a read of Diy HiFi Supply Tram Mk2 DHT OTL Preamplifier Take the direct route to the heart and soul of your music. Review By Clive Meakins. This is a very good review and things too do to tame microphonics.
Peter
Old 3rd January 2013, 09:22 AM   #524
kazap is offline kazap  Australia
kazap's Avatar
Ah - the Zen option. May I ask why you recommend no tube shielding? The presumed benefits of better cooling and less noise seems pretty useful for a simple DIY job, that even I can wire up without zapping myself.
Old 3rd January 2013, 10:09 AM   #525
Hugh, then you would not see the heater elements of the tubes at night. That is hypotonic to the eyes. It's like watching a fire. See the picture of my STC 4212E tube. I have had metal shielding in my Ah! CD player and I could not hear a difference. If the Full Music 2A3/SE are microphonic, then use the Herbie's Audio Lab Damping Instruments Guitar type dampners. The Full Music 45 ST shaped tubes are somewhat microphonic and I used the dampners with little difference in the noise heard.
From the review above: I'll put it simply; if you care about your music you must strongly consider this preamp. Don't let the potential need for fettling put you off but I appreciate that it won't suit some folks. As you can tell I'm over the moon with Tram Mk2, there's no way it's leaving my system.
Peter
Old 3rd January 2013, 04:33 PM   #526
beardman is offline beardman  Denmark
Hello Morten
good to get the polarity right
by me the steel tube works just fine--less mikrofony,,,alså use Herbie on my JJ 2a3
Bjarne
Old 3rd January 2013, 09:14 PM   #527
I simply don't see the point of these pipes... Tubes are designed run hot and to work perfectly fine without extra cooling, and how much will they actually lower the temp? A few degrees..!? That's a solution looking for a problem if you ask me. And since I have no hum what so ever they are not needed for grounding / shielding either.
Besides, as Peter mentiones: Tubes are beautiful, metal pipes are not.
Regards, Morten
Old 3rd January 2013, 09:19 PM   #528
As I remember it those 45's are mesh plates? Mesh plate tubes are too microphonic to be used in the Tram, also there has been a problem with hum with those Full Music 45's... Better stick to solid plate type tubes...
Regards, Morten
Old 4th January 2013, 07:37 AM   #529
Off subject. Has anyone tried the Full Music 300b/2.5V/c tubes in the Tram2. Instead of the 45 or 2A3 sound, you can get the 300b sound with the same heater current as the 2A3. Any response.
Peter
Old 5th January 2013, 11:41 AM   #530
Hugh. I have a Tram2 which inverts phase which goes into the STC 4212E amps single ended which inverts phase. I was told that my amps phase inverts so what I did was to listen to the normal and then inverted phase to the speaker connection. The phase inverted connection sounded better to myself and Keith Eichmann. So if you invert then invert again you should come up with normal phasing which should sound best. In my case it did not. I'm sticking with the phase invert connections to the speakers. It is what sounds best to your ears and not get hung up on technicalities.
Peter
I tried the normal and inverted phase of speaker terminal connects with my two phase inverted pre-amp and power amp equipment using a Wadia 3200 transport, Killerdac and ML3 Lenehan speakers with Dueland Caps. The result was quiet dramatic. The inverted phase sounded much better. Try it. That is what DIY is all about.
For people with extra cash, I tried a GEC U52 brown base single D getter rectifier tube in the Tram2. This tube rocks. It's the best. See picture of this tube. Click the image to open in full size.This tube helps with quieting the DHT hiss noise also. I have tried 1960s Sovtek 5U4, RCA, Tungsol, GE tubes and they do not come anywhere close to the GEC U52 tube. I tried the double cup getter U52 and the sound slowed with a relaxed sound.
DHT OTL Linestage - Tram 2Hide this!Advertise here!
C3M linestage costa23 Tubes / Valves 15 23rd August 2009 08:53 AM
C3m linestage bequerel Tubes / Valves 32 14th April 2009 06:03 AM
48V B+ linestage hirafu_boarder Tubes / Valves 24 11th May 2008 05:57 PM
Another linestage...... kianbach Tubes / Valves 11 28th June 2005 05:34 PM
:: linestage [Bryston B60] :: dhengkoel Solid State 6 26th September 2002 03:32 PM
