Go Back   Home > Forums > Commercial Sector > Vendor Forums > DIY HiFi Supply
DIY HiFi Supply Parts and Kits from Diy HiFi Supply
Old 29th December 2012, 11:28 PM   #481
Desmo is offline Desmo  Denmark
@Hugh... Yes, installing the Rod Coleman regulators on the chassis sides is possible and much easier than the installation I made... Geir did it, look a few pages back for his installation.
The downside with this is longer wiring at places where one want the wires short. Also, if you see my installation the heatsinks work as grounded shields where all the noisy stuff -wires to and from the rectifiers for instance- is all inside the ''box'' formed by the heatsinks.
But again: Using the sides makes for a very easy installation...
Regards, Morten
Old 29th December 2012, 11:35 PM   #482
The v3 Tram heater supplies are the same circuit as v1 and v2 with some component quality and value changes. I haven't yet tried Rod's heaters so I can't yet make the comparison, I just need to find the time.
Old 29th December 2012, 11:39 PM   #483
Originally Posted by clivetjm View Post
The v3 Tram heater supplies are the same circuit as v1 and v2 with some component quaility and value changes. I haven't yet tried Rod's heaters so I can't yet make the comparison, I just to find the time.
Hi Clive.
Yes, that was what I thought from the pics of the V.3... Then you (with the V.3's can look forward to the same improvement as we did
BTW. On the Rod Coleman regulators it gives another step of improvements in sound to upgrade the current sensing resistor and one of the caps (see my installation where it's explained). One might as well install these parts from the beginning...
Regards, Morten
Old 29th December 2012, 11:42 PM   #484
Originally Posted by Desmo View Post
Hi Clive.
That's what I hope for (and expect).
Old 29th December 2012, 11:50 PM   #485
Hugh, Morten has done the research and development into the Rod Coleman regulator installation. In your case, it will be much simpler to install these regulators per Morten's design during the assembly of the Tram2 rather than make the modification when you have an existing Tram2. In my case there will be drill swarf to remove from inside the chassis so not to get court against the electrical components. Morten has done it and this installation has worked for him. If you look at the threaded before the Rod Coleman regulator installation, Morten tried the supplied heater regulators with large heatsinks. His regulator installation look extremely neat with short connections between components. No long wires to pick up noise. Noise is what you do not want.
Hugh, you have some good ideas, but you should go with Morten's regulator installation during the Tram2 assembly.
Old 29th December 2012, 11:57 PM   #486
Hugh, when ordering the Tram2 from DIYHIFI Supply, ask Simon (contact at DIYHIFI) for a price without their heater modules. When I was at their old shop, all they did was assemble the kit from parts on the spares shelf. If you do not ask, you will have extra heater regulator that you will not use. DIYHIFI should utilize the Rod Colemand regulators in their kits. A must better solution.
Peter
Old 30th December 2012, 12:12 AM   #487
kazap is offline kazap  Australia
kazap's Avatar
Originally Posted by ptashton View Post
...ask Simon (contact at DIYHIFI) for a price without their heater modules...go with Morten's regulator installation... Peter
.... I will recommend getting ten extra caps t to get six of them in each channel....if you see my installation the heatsinks work as grounded shields where all the noisy stuff -wires to and from the rectifiers for instance- is all inside the ''box'' formed by the heatsinks.
thanks guys! Your all very kind and generous with your help.
I want a Tram2-MortenV4b- MusicFirst/2A3/SE
Old 30th December 2012, 06:54 AM   #488
Hugh, when ordering the Tram2 from DIYHIFI Supply, ask Simon (contact at DIYHIFI) for a price without their heater modules. Peter
That's a good idea, maybe they will swap the heaters for the 10 extra tinfoil caps needed..! You should ask for that Hugh and thanks for the kind words
Regards, Morten
Old 30th December 2012, 07:06 AM   #489
Not picking up noise is one concern, and wires not emitting noise is another. There are big currents running in the DHT regs, and on the ''ac side'' of the regs before and after the rectifiers there are large peak currents meaning that the wires can act as antennaes sending out noise. No matter how the installation is made, it's good to keep these wires as short as possible, and to have ground/shield between these wires and the preamp circuit.
At the other end of the regs, the wires going to the filaments on the triodes sould be considered as in the signal path, so these must also be as short as possible for that reason.
Regards, Morten
Old 30th December 2012, 09:06 AM   #490
I don't know why my picture of the RCA tubes disappeared, the user interface at Photobucket is totally changed, so maybe I upload the wrong way. I try once more...
These are the two pairs of RCA 2A3 tubes I have...
Regards, Morten
C3M linestage costa23 Tubes / Valves 15 23rd August 2009 08:53 AM
C3m linestage bequerel Tubes / Valves 32 14th April 2009 06:03 AM
48V B+ linestage hirafu_boarder Tubes / Valves 24 11th May 2008 05:57 PM
Another linestage...... kianbach Tubes / Valves 11 28th June 2005 05:34 PM
:: linestage [Bryston B60] :: dhengkoel Solid State 6 26th September 2002 03:32 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
