Go Back   Home > Forums > > >
DIY HiFi Supply Parts and Kits from Diy HiFi Supply
Old 28th November 2012, 04:34 PM   #441
GeirT is offline GeirT  Norway
Hi Clive,
My mounting of the regulator boards may be a bit dramatic; I simply glued them with 'super-glue' to the chassis sides. The regulators have electrically non-conducting packing that avoids short-circuiting.
If I had done it over again I would have soldered the regulators on the upper side of the boards so that are domewhat easier to remove/replace in event of failure.
Thank you about the tip to remove capasitor over the filament pins.
Geir
Old 30th November 2012, 05:03 PM   #442
Desmo is offline Desmo  Denmark
Hi Geir,
Thanks for the pictures, it's always cool to see other implementations :-)
The epoxy coating of the chassis is quite bad at dissipating heat, meaning that the junction temperature inside the transistors will be very high in your set-up. Don't expect the transistors to have a long life...
Also: You MUST remove the capacitors on the the filament pins, otherwise they will both color the sound and work as filters that alter the freq response. With those caps in place I understand why you heard a mellow bass, basically the cut off the bass range when used with the Rod Coleman regs.
Regards, Morten
Old 30th November 2012, 07:42 PM   #443
Thank you Morten,
I was about to get a second opinion about removing the caps over the filament pins.
Now I'll open the chassis and just remove them.
Not so sure about the heat build-up though as the regulators are not so very hot to the touch. But thanks for your advices anyway.
Geur
Old 30th November 2012, 08:05 PM   #444
That helped,
More air around the instruments :-D
Just bought a 'vintage' reel-to-reel tapedeck, a Revox B77 with new heads.
My oh my, I've never believed that this machine from mid-seventies could be so transparent and seemingly uncoloured!
I'm a happy guy :-)
And it's Friday
Geir
Old 30th November 2012, 08:10 PM   #445
It's off-topic but I simply love my new favourite toy;
The famous Revox B77 taperecorder
Geir
Old 1st December 2012, 08:04 PM   #446
Now I've measured the temp of the Coleman heater regulators with a thermo-couple I bought for the purpose today. It measures 40 degrees C directly onto the regulater 'plate'. It feels somewhat higher using my fingers but still that should be OK shouldn't it?
Geir
Old 1st December 2012, 08:16 PM   #447
What is a ''regulator plate''..? Do you mean the housing of the transistors? If you have 40deg celcious on the transistor housing then all is fine. I think it will be higher though, as your test with the fingers also indicate. If you can hold your finger on the transistor for a few seconds, then that indicate a temperature on around 60 deg celcious - and that is fine, especially if it's with 2A3 tubes...
Regards, Morten
Old 1st December 2012, 08:23 PM   #448
Rod Coleman is offline Rod Coleman  United Kingdom
работник
Rod Coleman's Avatar
DHT OTL Linestage - Tram 2
Yes, that's right - 40 to 60 deg C is OK.
70 deg C is the maximum temperature for the transistor case, or the heatsink (near the transistor).
Must be a good heatsink!
Old 1st December 2012, 08:28 PM   #449
He is not using a heatsink..! The transistors are just super-glued to the epoxy painted chassis. I'm a bit surprised if the temp is this low since a thick layer of epoxy paint + super glue between the transistor and the aluminium chassis could be a serious barrier for heat transfer... But apparently it works...
Regards, Morten
Old 23rd December 2012, 07:17 AM   #450
kazap is offline kazap  Australia
kazap's Avatar
Id like to buy a used Tram2 - please PM me if you know of one sitting on a back shelf.
Otherwise I wonder if anyone could build a two box version for me with the power and heater regulation in its own chassis to keep the tubed chassis cooler?
DHT OTL Linestage - Tram 2Hide this!Advertise here!
C3M linestage costa23 Tubes / Valves 15 23rd August 2009 09:53 AM
C3m linestage bequerel Tubes / Valves 32 14th April 2009 07:03 AM
48V B+ linestage hirafu_boarder Tubes / Valves 24 11th May 2008 06:57 PM
Another linestage...... kianbach Tubes / Valves 11 28th June 2005 06:34 PM
:: linestage [Bryston B60] :: dhengkoel Solid State 6 26th September 2002 04:32 PM
