Go Back   Home > Forums > > >
DIY HiFi Supply Parts and Kits from Diy HiFi Supply
Old 9th August 2012, 12:26 PM   #341
ptashton is offline ptashton  Australia
Morten, I asked Rod if he knew which power supply circuit you used in your Tram2. Rod said to ask you. So I did. Thanks for your reply.
Old 9th August 2012, 12:31 PM   #342
Desmo is offline Desmo  Denmark
My point is, that I did not ask him about what would be the best for a preamp application like this one, I just build one of them. So if you want his recommendation I'm sure that he will tell what he would have used
I can't comment on the other raw-dc designs, but this one does the job for sure. And by the way: I use 0.22 ohm resistors between C1 and C2 to make the regulators work. I know that Bjarne (beardman who is also using the Rod Coleman regulators in his Tram II) use 0.15 ohm. You will need to experiment a bit here to get the right voltage from the raw-dc supply so I recommend that you buy some different resistors to test with.
Regards, Morten
Old 9th August 2012, 12:57 PM   #343
Morten, I have just sent Rod an e-mail for his Tram2 power supply recommendation. By the way, what other audio equipment do you have in your system. You must have some great components. I am running an STSC 4212E single ended power amp with my Tram2.
Old 9th August 2012, 01:03 PM   #344
I hope he will recommend the one I have built...
WOW those SE amps look insane..! Very Interesting DIY project for sure...! This is my system...
Regards, Morten
Old 9th August 2012, 01:31 PM   #345
Morten, what Speakers are you using. The STC 4212E look fantastic when the heaters are lit up.
Old 9th August 2012, 01:40 PM   #346
The speakers are; Eggleston Works - Andra 3
Regards, Morten
Old 9th August 2012, 02:30 PM   #347
GeirT is offline GeirT  Norway
GeirT, where did you purchase your Rod Coleman Heater regulator kit. Do you have any info from Rod that you could share with this forum. Thanks
Hi, I ordered the kits directly from Rod sending him a pm via this site and adding my e-mail adress so he could send me the assembly and application manual. Everything he has sent me is of first order and he's a pleasure to deal with.
He signals that he is open for giving advices but I've not sent him any technical questions yet as I've been too busy to start buliding (and I'm still awaiting the Tram kit from HK).
Old 9th August 2012, 02:44 PM   #348
Morten, I have held back this question for a while but now I ask about the potentially obvious anyway; as transformer used for the Rod C. heaters do you use the two pairs of 9V AC secondaries from the existing Tram II power transformer? I cannot see that you have added any extra trafos.
Old 9th August 2012, 03:15 PM   #349
beardman is offline beardman  Denmark
Hello
Just use the 7.5vac..works fine here
Bjarne
Old 9th August 2012, 03:27 PM   #350
There are no extra 9V secondaries on my Tram II transformer, so I'm not sure what you are referring to. As Bjarne mentions, you must use the 7,5V widings for heater supply (blue + black) instead of the 5,5V windings (brown + black).
Regards, Morten
DHT OTL Linestage - Tram 2Hide this!Advertise here!
C3M linestage costa23 Tubes / Valves 15 23rd August 2009 08:53 AM
C3m linestage bequerel Tubes / Valves 32 14th April 2009 06:03 AM
48V B+ linestage hirafu_boarder Tubes / Valves 24 11th May 2008 05:57 PM
Another linestage...... kianbach Tubes / Valves 11 28th June 2005 05:34 PM
:: linestage [Bryston B60] :: dhengkoel Solid State 6 26th September 2002 03:32 PM
