#271 | |
Previously: Kuei Yang Wang
Raising the shunt resistances (to ground from -12dB and from -3dB to -12dB) will increase the level. If the total is raised by around 50% you get around 3dB more level. Ciao T |
#272 |
Thorsten, I implemented your recommendations to install the dropping resistors (total 0.16Ohm) from the power supply and rebiased with the VA 274B and Shanguang 2A3C tube combination.
Now, there is a very slight buzz noticable only a foot or two away from my Zu Druids (>97db efficient). Probably picking up some minor EM. Also noticed that my dimmer switch was throwing noise into the system also, so that is gone. Have some Herbies dampers arriving and have the unit on a set of StillPoints. Thorsten, I appreciate all the help and hopefully your recommendation can also be used by others. Thanks, Jeff |
#273 | ||
![]() Quote:
Ciao T |
#274 |
Wondering if anybody out there has tried a 6080 in place of the 6AS7 CSS tube? I'm mainly looking to reduce EM between tubes and lower noise even further.
T, is a 6080 even advisable? Thanks, Jeff |
#275 |
For tube rollers out there: as a follow up of my previous email, I bought an octal "socket saver" that raises the socket above the chassis cut out. Wide-base 6080 tubes can be used in the Tram. I have one in use now and it works great. Thanks, Jeff
#276 |
One of the Trams that I assembled developed a fault in the bias supply boards. See the pic. One channel supply is showing red diode next to its 2SA940 transistor. Bias voltage on that side is 16V only. This happened after only 6 months of normal operation.
What went wrong here? Is it possible to get a replacement from Simon?
The only true way is no way. |
#277 | ||
Ciao T |
#278 |
I am sorry it looks that I was too hasty as always. The red diode follows one of the valves. It is definitely the valve. I will get some spares today and double check. Thanks.
#279 | |
Ciao T |
#280 |
No problems - the tubes are NOS National Union 45s from ebay. Can't really claim warranty on them but they are easy to replace. I will suggest Emission Labs 45 to the owner.
| Thread Tools | Search this Thread |
| C3M linestage | costa23 | Tubes / Valves | 15 | 23rd August 2009 08:53 AM |
| C3m linestage | bequerel | Tubes / Valves | 32 | 14th April 2009 06:03 AM |
| 48V B+ linestage | hirafu_boarder | Tubes / Valves | 24 | 11th May 2008 05:57 PM |
| Another linestage...... | kianbach | Tubes / Valves | 11 | 28th June 2005 05:34 PM |
| :: linestage [Bryston B60] :: | dhengkoel | Solid State | 6 | 26th September 2002 03:32 PM |
| Page generated in 0.11082 seconds (79.84% PHP - 20.16% MySQL) with 11 queries |
