DHT OTL Linestage - Tram 2 - Page 17 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > DIY HiFi Supply
DIY HiFi Supply Parts and Kits from Diy HiFi Supply
Old 9th June 2011, 12:09 PM   #161
Previously: Kuei Yang Wang
Originally Posted by DECKY999 View Post
I checked all the wiring inside. PSU voltages are fine (a bit high due to 246V mains) - B+ at around 270V. All LEDs are ON everything seams to be working but no sound this time. Any suggestions?
+B at 270V suggests to me that the valves are not drawing enough current.
What is the cathode voltage to ground and the grid voltage?
Ciao T
Old 9th June 2011, 03:13 PM   #162
DECKY999's Avatar
OK, firstly do not forget that the mains voltage is close to 250V (246V to be exact). Therefore the output voltages are a bit higher than specified in the manual. For example the bias DC is -110V instead of -74V. I do not know if that makes any difference or not.
Measured grid to GND is around -9V. For the cathode ; pin 1 to GND is 2V; pin 4 to GND is 0.48. Heater supply is stable at 2.500V. For this ; plate to GND is 128V and reasonably stable. This is all with 45 valves.
I also noticed that it takes at least 30 minutes for plate voltages to stabilize and the bias is not the same as I left it - I do not know any more - I think I am getting a bit paranoid.
The only true way is no way.
Old 9th June 2011, 03:16 PM   #163
Decky, I wish you all the best in sorting out the preamp.
All the recent discussions made me finally get around to putting 45s back into my Tram II. As expected I needed to reset the heater volts but what I've not found before is that I had to reset one CCS which was showing 100V. I swapped the tubes around but they weren't to blame. I had recently noticed that one channel was a little noisy (rustling sounds). It was this channel that needed resetting, I expect a component has drifted, maybe the CCS variable resistor, it is very sensitive to adjustment in the first place. Anyway, I mention this as it's probably worth checking voltages every few months just in case of drift, heat from 2A3s could be a contributory factor.
Old 9th June 2011, 03:16 PM   #164
DECKY999's Avatar
Also there is - again - a significant coupling between the plate voltages when I try to adjust them. It really feels like chasing a ghost.
Old 9th June 2011, 03:19 PM   #165
DECKY999's Avatar
Thanks. In my case one pot is very sensitive and the other very lazy. The trouble is when I am close to around 100V if I adjust one the other one is changing - it is very hard to balanced them. I though before that it is CCS to blame - but they are brand new now.
Old 9th June 2011, 03:23 PM   #166
Both of mine are VERY sensitive and I have zero interaction between channels so what you have seems strange.
Old 10th June 2011, 12:33 PM   #167
There still seems to be something really wrong.
Can I suggest that you do some more trouble shooting.
It isolate issues I would suggest you temporarily replace the CCS with 560 Ohm / 5W. This creates a simple SRPP and the +B should settle at around 200V and you should see 0.38V across the two 12 Ohm resistors to ground at the DHT's.
This way you can be sure that the whole biasing circuit and the power supplies work 100%.
I would suggest to then test the CCS's by themselves (you can use a 9V Battery) and to set them, together with the parallel resistor to 31.6mA outside the Tram 2.
Then you can put everything back together.
The circuit is really quite simple, it should be pretty easy to find what the problems are.
Ciao T
Old 10th June 2011, 01:43 PM   #168
DECKY999's Avatar
OK thanks for the help - will try that tomorrow morning. I assume when you say CCS you refer to the whole PCB that holds the Ixys chip?
Old 10th June 2011, 03:35 PM   #169
Yes, whole PCB.
Just a thought, the CCS & PCB require a modification, as the CCS chip requires a "gate stopper", if diyhfs send you new chips and PCB's you may be missing this mod?
Ciao T
Old 10th June 2011, 03:49 PM   #170
DECKY999's Avatar
Also just to clarify, I should put 560R between the +B and the anode and leave the output not connected?
Can you just explain in more details how to set the CCS by themselves?
I do not know about that mod - I am reading the assembly manual R1.34 and the CCs PCB looks the same as the one I have (I have not checked all the resistor values). What is the gate stopper? You mean that cut track under the 5.1K resistor?
C3M linestage costa23 Tubes / Valves 15 23rd August 2009 09:53 AM
C3m linestage bequerel Tubes / Valves 32 14th April 2009 07:03 AM
48V B+ linestage hirafu_boarder Tubes / Valves 24 11th May 2008 06:57 PM
Another linestage...... kianbach Tubes / Valves 11 28th June 2005 06:34 PM
:: linestage [Bryston B60] :: dhengkoel Solid State 6 26th September 2002 04:32 PM
Copyright 1999-2017 diyAudio
