#111 | |
What happens with people who buy the amp assembled and expect a final product without wanting to modify anything? |
#112 | ||
Previously: Kuei Yang Wang
Location: Somewhere nice on planet earth where censorship of Ideas is frowned upon
Ciao T |
#113 |
Here is my calculation and you tell me if I am wrong. Under assumption that you have the series resistor in place and that regulator current to the ground is not more then 100mA dissipated power is P=(Vin-Vout)*ILoad+Vin*Ig where input voltage is 8.46V with 6VAC supply, Vout is 2.5V ILoad is ~1.88A yields with 12W of heat. If you assume the ambient temperature of 30C junction-case resistance of 2.7C/W, case - heatsink resistance of 2 and heatsink resistance of 8 - regulator junction temperature is 170degC.
Did I make a mistake somewhere? |
#114 |
The RMS voltage before the regulator is normally around 6V (you need to account for losses in the diodes and the ripple which at 2.5A DC is quite substantial), based on actual measurement, so it drops around 3.5V (a little less in reality due to some additional circuitry) with 2.5A Current, so real dissipation is around 8.5W. The heatsink I am not sure of the exact K/W, but based on my measurements of it's temperature I'd put it at 6K/W. The chip is around 2.5K/W and the insulation normally (correct assembly given) around 0.5K/W. So total thermal resistance is 9K/W and 8.5W will raise the chip junction to around 75 Degrees above ambient, which with the Tram II is likely around 35 Degrees. So Chip temperature would be expected around 110 Degrees, with some headroom (not much, admittedly) for hot temperatures and mains over-voltage. This also matches my tests on the actual supplies. Ciao T |
#115 | |
Also the same problems with the heater supplies - as you have probably read already. This pre-amp has soooo much potential it is a pity to loose control over such small details that can render the whole amp completely useless |
#116 | |
So all in all we agree they are borderline acceptable - I might try running 45 valves with extra heatsinks epoxied on the exiting ones - similar to what Desmo did. That might solve the problem . What do you think about putting the heater supply in a separate box with much bigger sink. Do you think that extra cable length you influence noise pickup significantly? |
#117 | |
Please add the resistors, you should be able to get heatsink temps in the 80 degree range with 2A3's. Ciao T PS, I am investigating the popped Capacitors. It appears the silk print on the PCB is inverted. What worries me is why these cap's, despite being reversed, have not been blowing up in ever so many Amplifiers in use for years and they only go in the Tram and only some times. I'll confirm the polarity later, but if you have C16 going again, try it reversed. BTW, the Cap does not much where it is anyway (added in a "belts and braces" fashion, it can also be safely left off. |
#118 |
OK no problems
I will try with the R33 resistor, extra cooling and a friend has a 240 to 220 step down trafo that will help as well. Keep me posted about that C16 - the same cap died in mine - it looked like the other side of the board in the pic but it is the same cap. |
#119 | |
![]() Regarding the heat issue on the DHT supply modules I tried first with the supplied 0.47 ohm resistors in series on the AC line feeding the modules, but the voltage drop was too much for the modules to regulate. I simply could not get a 2,5V DC on the output with 2a3 tubes. Then I tried 0,22 ohm resistors, but the highest DC voltage I could get on the output was something like 2,2V DC. I then dropped the idea with series resistors and instead I tried adding more cooling area to the heat sinks as you can see in a previous post. With the added cooling area the modules no longer get's unstable because of overheating (no more woofers flapping), but the chips/heat sinks are still extremely hot. My plan is to install larger heat sinks AND to improve the ventilation! Air can get in trough the bottom, but there is no way for it to escape through the sides or top. I think this will be needed to get a more ''permanent fix'' to this issue. Regarding C16 I had this reply from DIY hifi supply (through Peter at Acoustic Dimension in Holland where I bought my Tram). It's a bit difficult to understand from the message, if the cap should be reversed to the opposite of what's indicated on the silk screen? Or if he is talking about the need for a cap with higher voltage rating? Or both? Hello Peter, is the cap on C16 position? we just discovered that the +ve and -ve of the cap is inverted in the soldering. The problem doesn't show up in other application but only tram. We just discovered it. Seems like when the current of the tube is high then overheat the wrong cap. regards, Simon |
#120 | |||
The heatsinks should be at around 80 degrees in operation. Quote:
Funnily enough, this only seems to cause issues in the Tram and then only in a small number. It is no issue in any number of Amplifiers, inclusing one I have been running for more or less 3 Years every day... Ciao T |
| Thread Tools | Search this Thread |
| C3M linestage | costa23 | Tubes / Valves | 15 | 23rd August 2009 08:53 AM |
| C3m linestage | bequerel | Tubes / Valves | 32 | 14th April 2009 06:03 AM |
| 48V B+ linestage | hirafu_boarder | Tubes / Valves | 24 | 11th May 2008 05:57 PM |
| Another linestage...... | kianbach | Tubes / Valves | 11 | 28th June 2005 05:34 PM |
| :: linestage [Bryston B60] :: | dhengkoel | Solid State | 6 | 26th September 2002 03:32 PM |
