Turntable Parts Turntable Parts - diyAudio
Go Back   Home > Forums > > >
DIY HiFi Supply Parts and Kits from Diy HiFi Supply
Old 15th July 2009, 08:35 AM   #1
bcherry is offline bcherry  Hong Kong
bcherry's Avatar
Send a message via Yahoo to bcherry
Default Turntable Parts
Design:
-True Inverted construction. Ceramic ball bearing sits at the same plane as the drive belt, giving perfect alignment and bearing stability.
-Optimal lubrication. Oil feeder channels constantly push oil into the top section of the bearing for minimum rotational friction losses.
Hollow spindle allows adding lubricant from the top
Materials:
-nylon bearing plate at the top of the bearing case
-ceramic ball
-non-magnetic spindle
-non-magnetic phosphor bronze bearing case, nickel plating
the materials were chosen for their mechanical and tonal characteristics. This particular Japan-made phosphor bronze is very expensive and is used by a famous saxophone manufacturer, whose instruments are made from it in their entirety and are known for their deep rich tones. Remember that a turntable is a mechanical device and each material used contributes to it tonal balance - especially so the bearing.
Bearing fits 37mm thick platter, is 20mm in diameter and with a hollow spindle that extends 20mm from top of bearing.
Picture shows the bearing case before/after plating.
Includes: spindle, bearing casing, ceramic ball, nylon thrust pad, mounting bolt (extends up to 18mm for mounting in 1mm thick base)
I installed one in our well run-in demo BIX and had to turn back the speed a bit so very nice fit on these.
Disclaimer: I may or may not offer for sale items mentioned in this thread, and if I do, I may or may not make a profit.
Old 16th July 2009, 10:43 PM   #2
Jeffrey Davison is offline Jeffrey Davison  United States
Default Re: Turntable Bearing
Brian,
have you computed prices for these yet? All I found was the blog entry on your website and no pricing or availability.
Jeff
QUOTE]Originally posted by bcherry
Design:
Materials:
-ceramic ball
[/QUOTE]
Old 17th July 2009, 09:37 AM   #3
bcherry's Avatar
Hereon this page
Brian
Old 26th March 2010, 05:58 PM   #4
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 Turntable Parts
Brian do you have an image showing the mounting to a plinth, or at least a shot from the underside of the spindle with the mounting bolt fitted.
Thanks, very keen to try one in a new DIY deck.
Paradise Pre-reg PSU PCBs
Old 29th March 2010, 03:33 AM   #5
bcherry's Avatar
This is what i can lay my hands on. 2 lengths of mounting bolts are available to allow different thickness plinth.
Old 29th March 2010, 04:52 PM   #6
Thanks Brian...
Old 29th September 2010, 05:46 PM   #7
wjlamp is offline wjlamp  Greece
I am trying to enter this part of your site,but I am getting a denial flag.
Any clue?
B.L
Old 6th October 2010, 06:25 AM   #8
bcherry's Avatar
Sorry about that. Sold out. We are waiting for a production lot to arrive and don't accept any orders until they are in hand.
regards
Brian
Old 6th October 2010, 02:48 PM   #9
regards
Brian
Thanks for the responce.
You are kindly requested to let me, know as soon as, parts are in hand.
I am interested in the bearing.
B.L
Old 18th October 2010, 11:34 AM   #10
Fukinagashi is offline Fukinagashi  Italy
me too. please keep us informed!
TX
Turntable PartsHide this!Advertise here!
DIY turntable using parts from DIY Hi Fi Supply gadfly Analogue Source 6 9th August 2009 04:59 AM
Turntable for disc factory, many hanging parts , their theory , diy umutmt Analogue Source 0 14th November 2007 11:53 PM
AR Turntable Parts nedjinski Analogue Source 2 12th December 2004 07:27 PM
PARTS PARTS PARTS!!! Infocus Powerview 820, triplet, ballast, light, power supply!!! marioinla Swap Meet 1 31st August 2004 04:22 PM
which turntable is good for parts ? promitheus Analogue Source 4 8th July 2002 11:18 AM
Copyright ©1999-2017 diyAudio
