Go Back   Home > Forums > > >
DIY HiFi Supply Parts and Kits from Diy HiFi Supply
Old 7th October 2014, 01:03 AM   #11
twlai is offline twlai  Hong Kong
Thanks the web, I now know that it is a transistor "1F".
Old 10th January 2015, 12:18 PM   #12
tubeonly is offline tubeonly  Switzerland
Originally Posted by bcherry View Post
I want to draw attention to the centre-piece of the EZ Linestage: the UTS (Universal Tube Stage) module.
Hi Everyone,
I have bought a UTS for a MGL DAC. The UTS works properly with the supplied Telsa ECC 88. But a Siemens CCa burnt in 40 seconds. Is special precaution necessary in the choice of a NOS tube for the UTS?
Thanks for any advice!
Old 8th March 2015, 12:18 AM   #13
pawlus is offline pawlus  Canada
Ran a CCa in mine for months without problems. Also used 6922s and 6DJ8s without issue.
Old 8th March 2015, 10:02 AM   #14
Thanks, Pawlus.
In fact, the culprit was te tube. There was a fissure between the pins. It was difficult to see it.
The UTS runs very well with an Amperex 6DJ8 or a Telefunken E88CC.
Old 27th September 2015, 11:18 PM   #15
TV Man is offline TV Man
Can the UTS perform balanced to single ended conversion?
Old 1st April 2016, 02:16 PM   #16
bjohng is offline bjohng  United States
Is the UTS kit/pcb still available?
I want to try one with my TDA1541 but can not find it listed in the web shop
Posted a note on the companies web site but received no reply.
bjohng
Old 3rd October 2016, 08:01 AM   #17
Default More gain
I use Dual wm8741 and use the UTS. The gain is smaller than the opamp output. Is there anyway to increase the gain?
Old 3rd October 2016, 08:39 AM   #18
ozcal is offline ozcal  Australia
You can increase the gain from 6-12db by changing the jumpers.
Can't find the original uts manual but this link shows how to change from 6-12db gain : http://www.troelsgravesen.dk/EZ_Line...Line-Stage.pdf
Old 3rd October 2016, 09:05 AM   #19
The manual to set gain appears applicable when the UTS is used as a line amplifier. It is not in my case.
I also understand that the jumpers could be used to adjust gain. I simply do not which jumpers should do.
Attached please find the UTS manual.
Old 3rd October 2016, 09:10 AM   #20
The manual is here:
https://www.dropbox.com/s/oqcbgbh862...1loRz.pdf?dl=0
UTS - Universal Tube StageHide this!Advertise here!
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 16 18th May 2013 03:19 PM
UAS - Universal Amplification Stage Stee Solid State 70 12th November 2010 01:23 PM
Developing a "universal" tube power supply PCB Geek Tubes / Valves 42 15th August 2007 07:10 AM
Tube Output Stage Mighty Mouse Tubes / Valves 3 24th August 2004 08:08 PM
Tube I/V Stage TV Man Digital Source 0 2nd September 2003 04:39 PM
