Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 16th January 2003, 09:33 PM   #1
Default Newbie CD transport question
What makes high-end CD transports expensive? From what I have been able to pick up, enormous effort is made in reducing jitter at the output of the transport (S/PDIF data stream). The DAC then expends considerable effort recovering the clock from the S/PDIF with low jitter.
Why not put an ultra-low jitter clock on the DAC, put a FIFO before the DAC, and use a simple servo loop to slave the transport clock to the DAC clock? The servo would just have to be good enough to avoid data over or underruns in the FIFO.
What other functions are typically done by the transport? Error/skip correction? Am I missing something fundamental here?
I apologize if this issue has been discussed before, I'm a newbie and didn't find much while searching the forum.
Mike
"Never confuse motion with action." B. Franklin
Old 16th January 2003, 09:42 PM   #2
Elkaid is offline Elkaid  Canada
Elkaid's Avatar
Send a message via MSN to Elkaid
Several manufacturer put a lot of effort in vibration damping mecanism.
TEAC (and probably many others) has a system called VRDS which is pictured below.
I suppose that's it's a way to justify a part of high price CD transport.
Old 16th January 2003, 09:54 PM   #3
Banned
this suspension and anti vibration stuff is what a manufacturer is easyily able to do, not too expensive, consumer belive it improves something, and its usefull for the marketing guys... ok, maybe it helps - but does a well designed transport needs this addidtional stuff?
take a look at different transports.
http://www.daisy-laser.nl/
Mr. Thevissen from daisy laser explayned me, if i understood him right, there are two kind of transport. Those that sell for about 6 USD each if you buy >1000, and those that are >200USD each. One difference is software, another how stiff is the construction (have a look at CD PRO 2)
- and main difference if there is electronics behind the laser on the moving head (good, expensive, less errors) or is there only the laser diode on the moving head and a "long" (few inch?) cable to the electronics (cheap, head has less weight, weak actuators possible... and more errors because signal from diode comes with lot of noise or so)
Old 17th January 2003, 12:10 AM   #4
I guess my question is why the vibrations need to be damped to such an extreme. Is the bit error rate (BER) actually significant in a poorly damped transport? If the data can be synchronized with the DAC clock, then it seems to me that the only thing that matters is an acceptably low BER.
Mike
HDCD Transport Question Eargasm Digital Source 13 21st December 2009 01:51 AM
8 channel 24/192 DAC: The transport question NeoY2k Digital Source 5 21st April 2008 08:36 PM
Newbie - how to start modding my transport? jsmccray Digital Source 4 29th November 2006 12:46 PM
CD transport Question: Quality? maxw Digital Source 4 21st October 2004 07:17 PM
newbie post, but hopefully not a newbie question wiredcur Solid State 3 24th August 2002 10:49 PM
Copyright ©1999-2013 diyAudio
