Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
CS8420 and CS4397 question
Old 16th January 2003, 07:57 AM   #1
macsaif is offline macsaif  Slovakia
Default CS8420 and CS4397 question
Hello!
Last night I have listed the datasheets of CS 8420 and 4397. I have read the 8x interpolation mode is allowed to use only when the input signal format is like in BB DAconverters. It means separated L/R data signals. I want to ask you, which solution is better?
1. Change sample rate frequency to 96kHz by CS8420 and use CS4397 in I2S mode
2. Use 44,1kHz sample rate frequency, change signal format to DIL/DIR/BCLK...(as in BB converters) and use CS4397 in 8x interpolatin mode.
Which solution gives better sonic results? I think the high level of oversampling will degrade the signal.Have you circuits for serial audio signal converter(Not BB DF1704 ...)?
How does the sample rate converter (and interpolator) work? For ex.: the input is 16bit,44,1 kHz. If I resample it to 24bit,96kHz the additional samples are calculated from incoming samples.Am I right or 24 bit means only fitting 8MSB bits by 0? Are the sample rate converter and the interpolator same?
Thank you!
Best Regards/ S pozdravom/ ▄dv÷zlettel
Frank
CS8420 and CS4397 questionHide this!Advertise here!
Newbie question: How to battery power my cs4397 dac kit boidos Digital Line Level 2 31st May 2009 10:35 PM
dac pcm1794 vs cs4397 evert1 Digital Source 2 19th October 2008 03:36 PM
Is the CS8420 really that bad? ABO Digital Source 64 16th July 2008 05:36 PM
need help for UPGRADE CS4397 DAC DIY KIT nickthevoice Digital Source 1 3rd May 2008 10:32 PM
CS4397 and Zapfilter II N.S. Digital Source 10 31st January 2008 02:36 PM
