Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
sine wave with 1% residual distortion
Old 10th April 2007, 04:06 PM   #11
jcx is offline jcx  United States
upped the time steps to 30 seconds each, includes .wav, .asc
Originally posted by jcx
the zip should contain a 2 channel 16 bit 44.1K .wav
1st second 1 KHz -3 dB, no added distortion
left channel 3rd harmonic
1% 1-2sec,
2% 2-3sec,
3% 3-4sec,
4% 4-5sec,
5% 5-6sec;
right channel 1% distortion component
2 KHz 1-2sec,
3 KHz 2-3sec,
4 KHz 3-4sec,
5 KHz 4-5sec,
6 KHz 5-6sec;
runs better than 1/2 real time on my machine, big delays also when LtSpice tries to load data into waveform viewer
SwCad could be run in batch mode to skip waveform viewer
@192K zip was too big, used 7zip ( 31M wav=>24K .7z, not bad but you could say that the 31M is "encoded" in the 2K .asc file, just takes a little longer to extract )
http://www.7-zip.org/
and of course, diyAudio doesn't recognize .7z, so rename without .txt and open with 7zip
Old 10th April 2007, 04:41 PM   #12
Bernhard is offline Bernhard  Germany
Bernhard's Avatar
How to remove the .txt in XP ?
Old 10th April 2007, 05:12 PM   #13
rt clik on filename and a dialog should open, select Rename
or select file (left clik filename or icon) and use <File> tool bar to get to Rename cmd, left clik 2nd time (wait some time not double clik) directly enters Rename mode
then you are able to edit the file name, left clik inside brackets containing the highlighted filename to get ordinary cursor with normal line edit behavior, <cr> or cliking outside brackets ends edit
ignore the warning/ clik OK/Yes when when you finish
Old 10th April 2007, 08:25 PM   #14
Bernhard's Avatar
...got it now, problem was file extensions were not shown...
Thanks, nice files, give also good idea how sounds -40db of K2 to K6.
It shows 0,035% for the clean wave and 1,001% for K2, dropping to 0.99% for K6.
I increased sampling points x4 and it dropped down to 0,015% for the clean wave.
Still much 2 much, maybe more averaging could help.
Don't know how good was the guy who wrote the program, I understand maybe 50%.
sine wave with 1% residual distortionHide this!Advertise here!
Sine Wave Generator with bulbs (Sine-lightenment) Rodeodave Everything Else 6 21st July 2008 12:19 PM
Sine wave - Square & Triangle wave generator using Transistors / OP-Amps lineup Solid State 20 9th October 2006 12:15 AM
Pure sine wave? PeteMcK Multi-Way 12 4th July 2004 06:31 AM
