Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 23rd March 2007, 02:38 PM   #1
gorfeas is offline gorfeas  Spain
Send a message via MSN to gorfeas
Unhappy Sony CDP-X222ES tracking problems
Hi there, been having trouble with a second hand sony cdp-x222es.
The player has better sound than my old marantz cd 46, and so I would like to try and "salvage" it.
It tends to skip and/or get stuck at the end of cd's with many tracks (16+).
So far I have cleaned the lens (no help), and tried to adjust the mini pots located near the lens (laser-power??). The problem is that there are 3 of them, anyway, I only rotated 1 of them about 10 degrees. Now the player got a little better, however it keeps getting stuck at the outer extreme of the disc.
I will try to clean the mechanisms too, although the player is in good condition inside (not too much dust).
Any suggestions? Also I am trying to find the pickup replacement but no luck until now...
Please help me out here...
Sony CDP-X222ES / McIntosch 6100 intergrated amplifier / Fostex fe-103 backloaded horns (DIY) / DIY cables + interconnects
Old 23rd March 2007, 03:29 PM   #2
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Try cleaning and relubricating the slides and drive mechanism. Old lubricant tends to get sticky especially near the end of the travel. There are quite a few threads around on what to use and I've found Tamiya switch grease works well. If you can get your hands on some Molykote EM-30L, even better. PBR rubber grease (castor oil based for car brake parts) is supposed to be good, but have yet to try it. Don't use any silicon spray or products as it works it's way everywhere.
Don't play around with the pots on the laser as they are factory set. You should be able to find the KSS240A laser for it if required as it's very common.... I'm sure that's the right one.
Old 23rd March 2007, 03:35 PM   #3
Netlist is offline Netlist  Belgium
Netlist's Avatar
Default Re: Sony CDP-X222ES tracking problems
Replace the flat cable (pos. 202 on your drawing)
/Hugo
Old 23rd March 2007, 07:33 PM   #4
thanx for the advice rabbitz!
it worked (at least the first cd that used to cause problems...)
I just finished cleaning and greasing and the disc played smoothly. Returned that pot at default position too.
I also blew the s**t out of that lens with some cleaning blower i had around.
thanx again.
I had already bought the schematics though thinking in future mods-tweaks.... I do not have ANY experience in electronics apart from the speakers I once built and basic circutry knowledge. Will try to start reading other mod projects and try to make some power supply first.
see you guys
Old 24th March 2007, 06:33 PM   #5
rabbitz's Avatar
The only thing I've modded on the Sonys is to change the final output opamps to OPA2134 or AD825 and changed the output coupling caps to Black Gate NX.
An example is the CDP-X55ES (see schematic) and only changed IC407, IC507 to AD825, changed C414, C514 to 47uF BG NX and removed the by-pass caps C415, C515. Didn't have to do any more than that as was an ample improvement. Any other opamp tried in IC406, IC506 degraded the sound so the original 5532DD remains.
There are heaps of mods around when you start looking.
Old 19th April 2007, 07:08 AM   #6
A little update:
I cleaned the insides of the sony thoroughly, by blowing air and removing old grease. Then re lubricated the axis of the sliding mechanism with ceys lithium grease (the white stuff).
The player got a lot better. However with most of the cd's when reaching the end of the disc (the outer diameter) it start misreading and skipping etc.
Is there anything else I can do before ordering a replacement laser pick-up?
Old 20th April 2007, 02:42 PM   #7
Scorpio(DDMF)!'s Avatar
Since the player starts skipping near the end of the CD, when the speed of the rotation is lower, you can check for disc "wobbling" eg. increased vertical motion...
If that's the case, you may have a problem with the spindle motor and/or the clamping mechanism
BTW: If you are changing the laser, it's a good practice to change the spindle motor also (acording to some more expirienced people on this board ).
Hope it helps...
"Yes, yes, I know numbers don't lie!" - Foghorn Leghorn
Old 26th April 2007, 01:10 PM   #8
Default tracking solved - MODS???
Hi there, tracking problems seem to have almost disappeared after thorough greasing. It is a fact that the cd disc perimeter does seem do "tremble" slightly while rotating. Should I change the motor? could greasing the motor axis help?
anyway as it looks as if the problem is gone I was planning on doing some modding to get me started as an electronics diyer.
I am posting here various photos as well as a schematic i have found in order to make it for you easier to make suggestions.
Formerly i used a marantz cd43, which had a philips DAC if i recall well. Then the sound was poorer but it had more focus.
Would changing all those caps help me get back the focus?
This is what I think is "replaceable":
c527 - 47uF 50V
c627 - 47uF 50V
c201 - 100uF 63v
c214 - 220uF 16V
c211 - 220uF 16V
c209 - 470uF 16V
c204 - 1000uF 16V
c210 - 1000uF 16V
c205 - 4700uF 16V
and what about the values of the replacing capacitors? should they have the exact same value of capacitance and/or voltage?
How about PSU? it would be a good idea to make a new one I reckon. Any suggestions/designs?
here are the photos:
The player uncovered:
the player's PCB:
Do these also need replacing??? what should I change them for
q206 - Click the image to open in full size.
q218 - D1944/K111
q210 - B1274/R1A2
The PSU transformer.
transformer bottom
tranformer top view
and last the schematic
Sony CDP-X222ES mods gorfeas Digital Source 5 6th November 2008 04:23 PM
Sony CDP X222ES Service Manual powerear Digital Source 1 19th September 2006 12:20 PM
Sony Cdp-x222es wovo Digital Source 1 10th May 2006 08:51 PM
Page generated in 0.12231 seconds (81.34% PHP - 18.66% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
