| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
There is a discussion on a Chinese forum that the DIR1703 and AD1865 do not match without shift logic. Since the AD1865 data format is right justified, if I select the 16-bit right justified format for the DIR 1703 to capture 16-bit SPDIF, then all the AD1865 sees is 2 bits of 0s before the MSB. It would seem to work without shift logic. Will it work? K K |
#2 |
hi can you help?
I have usb module from dddac that output a i2s and cd denon dcd-2650 with 4 ad 1862 , I want transformer in a usb dac 1862! is possible? |
#3 |
Hi nicoch46,
If I understand you correctly, you want to change a 16-bit I2S signal to a 20-bit right justified one. I think this might help: http://www.geocities.com/nonospcm17...al_shifter.html In this case, the data will be right shifted by 11 bit so that the 1862 sees the the last 20th bit as the MSB. I have simulated the logic in Pspice but have not tried it for real. So can you get the 2707 in dddac to work ? Lucky fella. My own circuit has not been successful. Of about one thousand times I plugged in the chip, I have only one positive response from the computer. Other times the computer always return the messasge - device not recognised. I don't know if others also find the chip hostile. Having read another post I think I can answer my own question in post #1. I will set the 1703 in 16-bit right justified mode and shift the latch clock by 2 bits. Then the MSB will align. Cheers, KK |
| AD1865 the best DAC | audiodesign | Digital Source | 348 | 4th January 2012 01:45 AM |
| Burr Brown DIR 1703 | snoopyma | Digital Source | 2 | 19th April 2007 03:04 PM |
| adding SRC to 1703 +1738 | takashi | Digital Source | 2 | 27th January 2005 02:33 PM |
| minor problem with DIR 1703 | WTS | Digital Source | 0 | 29th March 2004 10:56 PM |
| DIR 1703, DF 1706 and PCM 1730 | demeter | Digital Source | 0 | 11th August 2002 11:39 AM |
| Page generated in 0.07546 seconds (78.25% PHP - 21.75% MySQL) with 10 queries |
