Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 19th March 2007, 06:34 PM   #1
audiosteve's Avatar
Default DIY ADC info ?
I have searched the threads and am coming up short.
Does anyone know of a good DIY design or kit for an ADC? I have found plenty of data on DACs, but data on an ADC seems sparse.
I need something to feed a DSP.
Thanks,
Steve
Old 20th March 2007, 07:45 AM   #2
How about a Cirrus Logic evaluation board ? It shouldn't be too hard to get one.
Old 20th March 2007, 08:01 AM   #3
Werner is offline Werner  Europe
One possible way could be to buy an ADC evaluation board from TI or AD, add suitable power supplies, and adapt the analogue front-end to your needs.
I've got a board for the PCM4202, but haven't got the time yet to play with it.
bring back dynamic range
Old 20th March 2007, 02:27 PM   #4
audiosteve's Avatar
Good suggestions. I can probably get an EVAL board from Cirrus. I have an in there. wink But eval boards are usually larger and have more components on them then necessary for just the base functionality. I am trying to find something more compact and purpose built. If any one else has any suggestions I am still listening. If all else fails, I will go the eval route.
Thanks,
Steve
Old 20th March 2007, 10:27 PM   #5
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
The only real DIY ADC I'm aware of: http://www.beis.de/Elektronik/ADDA2496/ADDA2496.html
/U.
Old 20th March 2007, 10:55 PM   #6
Banned
http://tinyurl.com/2t8a4f
Old 21st March 2007, 12:52 AM   #7
audiosteve's Avatar
Thanks for your suggestions. It looks like either of the DIY projects could be made to suit my needs. I may be able to get a freebie CDB5381 from Cirrus but if not the price for this board at Digi-Key is $360!! That's a non-starter.
Old 21st March 2007, 05:15 AM   #8
hagtech's Avatar
You can try something like this. Use 0.22uF or larger capacitors to couple to the inputs. I forget exactly, takes something like 0.5Vrms input for full scale.
I use "Audacity" software for recording. The chip also plays back with DAC outputs. Or create and SPDIF signal to connect to another DAC. Very layout sensitive.
jh
Old 21st March 2007, 06:33 AM   #9
audiosteve's Avatar
Thanks for that post Jim. If I could use spdif it would probably do the trick but I need something with LJ or I2S out. I'm still looking and won't make a decision until I think I have done enough homework. I'm really amazed that there are a million DAC's out there but precious few resources for a DIY ADC.
Old 21st March 2007, 07:30 AM   #10
Have you considered designing one ?
Need info on my Onkyo, can't find any info anywhere. gixxierific Digital Source 0 19th April 2009 03:49 PM
How to get cathode bias info from grid bias info? leadbelly Tubes / Valves 8 14th August 2008 04:40 PM
need info for Zen-XA amp space2000 Pass Labs 5 20th June 2008 03:33 AM
Info ?? lpd Solid State 1 16th August 2006 10:54 PM
Page generated in 0.10088 seconds (78.63% PHP - 21.37% MySQL) with 10 queries
