Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 19th March 2007, 09:04 AM   #1
georgehifi's Avatar
Send a message via MSN to georgehifi
Default Teac VRDS-10se Analog Stage mods?
I think I'm going to end up with this as a transport, the da stage is twin TDA1547's and a small (yeah right) sprinkling of opamps, can anything be done with is, or are the TDA1547 a lost cause, I've never heard much about them. I will post the semiconductor parts list separatly.
I have my own modded MF A3.24 outboard dac (PCM1738e) which blows this intergrated one away at the moment, when both use the 10se as a transport.
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 19th March 2007, 09:05 AM   #2
georgehifi's Avatar
Parts List
Cheers George
Old 19th March 2007, 01:49 PM   #3
protos is offline protos  Greece
protos's Avatar
This site has some extensive non-os modding on a vrds 25 .Pretty close to your player.
http://www.geocities.com/teac_vrds_25x/
``The author always assumes that when power is applied , the amplifier will explode or ,at the very least, catch fire.´´
Morgan Jones, Building Valve Amplifiers.
Old 19th March 2007, 07:51 PM   #4
georgehifi's Avatar
Thanks protos, very interesting read, unfortunatly the 10se is very different to the 25x as far as the da and analog stage goes, and its not much help, but I did save it all just in case one day I end up with a 25x.
Cheers George
Old 19th March 2007, 08:34 PM   #5
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
VRDS-10 update; replace/upgrade the digital filter. http://www.audiotuning.de/english/in...?1-3-teac.html
Then add an extra trafo for the analog-part/board. (Use the stock for digital/transport).
Then; op-amps...
Arne K
Ars longa, vita brevis
Old 19th March 2007, 10:35 PM   #6
georgehifi's Avatar
Cobra2 hi, I don't like playing around in the digital side of things as I'm not savy with it. I was thinking more about using the unused pins 10 11 22 23 on the TDA1547's (bypassing it's internal opamps) with some other system instead of all those opampamps servo's and mute transistors. Has anyone had any experience with this, and more important are the 1547's worth it? as I've not heard anyone say these are good or bad dac chips.
Cheers George
Oops! just looked at the 10se diagram again they are bypassing the internal opamps by using 10 11 22 23 any other ideas?
Old 20th March 2007, 01:25 AM   #7
georgehifi's Avatar
I've come across this using the SOT1 transformers, but all of the diagrams are for one TDA1547 in stereo mode, I have two TDA1547, would anyone know a cofiguration for two of them?
http://digilander.libero.it/paeng/a__tda1547_tweak.htm
Cheers George
Old 20th March 2007, 04:09 PM   #8
protos's Avatar
Well having looked a bit at your schematic for the analog stage it seems that there is a lot one can do there.It is different somewhat to the vrds 25 but the general mod principles applied there also should apply here.There are far too many op-amps in the signal chain and the objective is to limit them.I think the last opamp must be a dc servo if I am not mistaken and the transistor at the output may be a muting transistor.
You could upgrade the opamps of course without changing the circuit.There are special vertical adapter boards.You could do away with the muting transistor,etc,etc.
As for the 1547 chip the 1543 and 1541 are all the rage now with non-os so perhaps it is not bad.
An easy upgrade is of course a high quality clock module.Also easy is the power supply.You could easily substitute some good superregulators (i.e.ALW) there.
TEAC VRDS P30 mods? Studley Digital Source 1 22nd April 2012 06:00 AM
TEAC VRDS-10 vs VRDS 25X Pani Digital Source 12 3rd April 2011 04:03 AM
Teac VRDS 10se fuse Telstar Digital Source 7 3rd April 2011 03:29 AM
Teac VRDS-20 mods Blaz Digital Source 4 11th February 2007 07:36 PM
TEAC VRDS 10SE service manual webercarbmann Everything Else 10 30th November 2004 12:10 PM
Page generated in 0.10378 seconds (78.50% PHP - 21.50% MySQL) with 11 queries
