Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 17th March 2007, 12:22 AM   #1
joe is offline joe  Germany
Default part# for spare part for CDM-1 wanted
I'm looking for a spare part for a CDM-1 transport.
It's part #52 on the attached drawing. Someone glued the teflon screw (#51) in and I can't get if off.
Does somebody knows the Philips part number of this part? Then I could try to order it.
Thanks.
Old 18th March 2007, 07:34 PM   #2
oshifis is offline oshifis  Hungary
Joe,
Get a Torx screwdriver of proper size, and it will come out easily. But you don't need that special screw in any case. It can be replaced with a brass screw of same size, the bottom flattened with a file and fine sandpaper (or better machined flat.). The bottom of the spindle is round, and it slips on the flat surface. A very small amount of oil might be useful here.
Old 18th March 2007, 08:06 PM   #3
Thanks for your reply but there is absolutely no way to remove the screw in this palyer as somebody has glued it in. I could drill it out but then I have to re-cut the thread and I don't know it's size. It doesn't look like a standard thread but as you've said that a brass screw fits I might be able to identify the thread with this new information.
Btw. I already have a new teflon screw, one can buy for about 2,5 Euro, so that's not the problem.
joe
Old 18th March 2007, 08:32 PM   #4
Geoff is offline Geoff  United Kingdom
Default Re: part# for spare part for CDM-1 wanted
The Philips part numbers are listed in the table below the exploded diagram (see attached). For example, 52 is 4822 520 10529.
Old 19th March 2007, 11:03 AM   #5
Excellent!
Thanks Geoff
Old 20th March 2007, 08:59 AM   #6
Joe,
I measured the screw for you. It is M6,5 x 0,5 thread, 3,5 mm long. There is a hex key (Allen key) slot of 2,5 mm at the bottom. There is a steel pad of D=2,5 mm, 0,5 mm thick glued at the top. So the ballpoint end of the spindle is supported by this steel pad, not slipping on teflon. I suppose it will be hard to find a replacement, but perhaps a skilled mechaniker can do it for you.
Wanted ~ Lowther LL26 Amplifier ~ ***Excellent Price ***paid or swap/part ex TheMooN Swap Meet 0 11th October 2008 09:19 AM
what part can take the place of ST part VB408B completely peterchen88 Parts 0 8th September 2007 06:45 AM
Thorens 320 spare part otto Vendor's Bazaar 0 7th August 2007 07:27 AM
Looking for spare part sources for a Ford Windstar Eva The Lounge 3 15th October 2006 04:11 AM
spare part Arcam Alpha 5 cd player paul_g Digital Source 7 3rd September 2006 10:06 AM
Page generated in 0.08933 seconds (72.72% PHP - 27.28% MySQL) with 11 queries
