| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hello,
as mentioned in a previous post I am looking to upgrade my CD Player. One of the areas of intervention is the I/V and buffer / filter stage depicted in the schematics attached. What is sure so far is that R4-R6 and R9 will be upgraded with Riken resistors, C6 subsituted by a Black Gate N type, IC1 will be substituted by 2 OPA627BP on a Browndog adaptor, IC2 the same or OPA2134 (need to check both). The follwong components being left and: 1) I have problem sourcing capacitors in so small values 2) I am not sure on the type of resistor I should use in the feedback networks of the ICs. 1) I wanted to source som RelCap TEs but I have problems getting those, so I am think about alternatives. The only ones I found so far are - 4,7nF Wima FKP2 - All other values and 4,7nF I can only find Silver-Micas or Styroflex. - Currently some non defined yellow caps are in, look like small MKTs Which ones can be recommended in which position? 2) I have some spare Rikens left but I am not sure whether they would suit the application. I have a hard time finding Caddock MK132 or Vishay Dale CMF55 in 620Ohms. Can I leave the original metallic ones in place or do you recommend the Rikens or or or... Your help is very much appreciated. Patrick |
#2 |
Patrick,
in my Bitstreamed player from Meridian I have the same output concept. The same topology is used for very high grade (digital) meters, the aim being the offer of a completely symetric & balanced load to both outputs, with an extreme PSRR. However, the setting is very prone to 3rd harmonics and needs carefull adjustment! But, do we need this complexity in audio? A schema has been placed on the DIYaudio that uses a Nelson Pass balanced concept that only at the output links the two outputs (C43) for some filtering. The advantage: no feedback, no complex phase shifts. No slew rate limitations as the current pump does it's work... This looks a good alternative to your setting, is simpler too to build. Comment on the value of the summing resistor: Given the fact that it is running into 1.500 ohms it has been designed for a +/- 2 mA current source. I am not sure if this is the same as you have (because you have a 620 feedback resistor).
| Analogue output stage | maxpou | Digital Line Level | 0 | 18th April 2009 02:48 PM |
| TDA1540 analogue stage | dariusku | Digital Source | 2 | 9th September 2005 07:01 AM |
| Battery powered op-amp analogue stage of DAC | wreeve | Digital Source | 5 | 23rd August 2005 07:43 PM |
| cdp analogue stage tweak | ohynot | Digital Source | 2 | 11th July 2004 08:36 AM |
| Seperate analogue stage after DAC chip | Bas Horneman | Solid State | 4 | 8th April 2002 11:37 PM |
| Page generated in 0.07549 seconds (74.05% PHP - 25.95% MySQL) with 11 queries |
