Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 9th March 2007, 07:17 AM   #1
DaveNZ is offline DaveNZ  New Zealand
Default Mission PCM7000 parts needed
Hi all, I've got a Mission PCM7000 that has a clock issue (I think). I know there are some models of Marantz and Philips that share circuitry, what models should I be looking for? Was thinking about using the audio board from the Mission with the drive board from whatever I can get. I still think the PCM7000 is a good sounding machine, or should I just bin it?
Thanks..........
Old 11th March 2007, 07:27 AM   #2
Someone must know...........
Old 11th March 2007, 09:09 AM   #3
stoolpigeon's Avatar
I have a PCMII somewhere which is from the same time and I believe the main pcb is similar to a Marantz CD56 or Philips CD650. Just Google Philips CD650 on Images and you will see photos of the internals.
But what's wrong with it?
My recollection is that these machines have the servo pcb mounted beneath the laser and it is this part which can have problems. The trouble is (being Philips) there are quite a few variations of servo pcb and main pcb.
Old 11th March 2007, 12:30 PM   #4
Default Re: Mission PCM7000 parts needed
Thanks..........
What is the clock issue and what chipset does it use ?
Old 12th March 2007, 05:13 AM   #5
I believe the nearest players are Magnavox FD1040, McIntosh MCD7000 and Bang & Olusen CDX.
Almost all symptoms one can get with any of these are caused by cracked/cold solder joints on the upper main board(servo & signal proc), ESPECIALLY & infamously the solder "blobs" that are used to connect the bottom side foil traces to the top side groundplane foil. These are easily found from the top side, and should be resoldered from both top & bottom to assure solid through connection. Even better, stick a piece of wire through each hole(while solder is molten or removed) & then re-solder. Then resolder everything on all boards that looks even slightly suspicious.
About the only other thing slightly common on these is wear on the bottom bearing of the platter motor, which can be adjusted to compensate for material loss.
Philips cd650, Mission PCM7000 differences ? ash_dac Digital Source 44 21st May 2009 10:45 AM
Mission PCM7000 with poorly laser mixter_v Digital Source 39 13th November 2008 06:45 PM
Mission M74 Tweeter upgrade needed. Marsh Multi-Way 0 18th April 2007 02:13 PM
KEF parts needed Armadel Multi-Way 0 11th January 2002 08:16 PM
Page generated in 0.07329 seconds (75.82% PHP - 24.18% MySQL) with 10 queries
