Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
CD960 tray problem...
Old 3rd March 2007, 07:12 PM   #1
Skorpio is offline Skorpio  Denmark
Default CD960 tray problem...
The tray will not open or close. If it is helped a little with a finger I will move, but not without....
It could lack some oil or lubricant? What to do?
Old 3rd March 2007, 08:18 PM   #2
tone arm is offline tone arm  Singapore
hai, iv been thru with diz kindof problem before, what i did was get the tray motor replaced and it works. you can source the motor from any philips cdm4 tray mech. good luck.
Old 3rd March 2007, 11:07 PM   #3
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
You may have a missing tooth on the drive gear, if so read here.
http://www.diyaudio.com/forums/showt...98#post1149198
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 4th March 2007, 09:25 PM   #4
Where is the tray motor and is rework possible?
Dont think it is gear because it can work with a little help....?
Old 5th March 2007, 06:15 AM   #5
tubenut is offline tubenut  South Africa
tubenut's Avatar
Belt?
Guillaume
Croak Audio Exploration
Old 5th March 2007, 08:54 AM   #6
Belt seems ok......but perhaps tension on it?
Old 6th March 2007, 08:44 PM   #7
Default Loose part inside...
When I opened the played a part was loose inside. With a little shake it fell out. It was a little metal pin or axle....2mm in diameter and 10-11mm long....with hard surface...like a capstan axle on a cassette player.
Anybody know what it could be? Possible a part of the tray mechanism?
Old 6th March 2007, 11:22 PM   #8
It seems to be the two belts, the motor is running but they do not move the wheels....
Anybody knows the types?
Old 17th July 2010, 01:31 PM   #9
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
go to
Help with Philips CD960
Old 15th August 2016, 03:52 AM   #10
napovo is offline napovo  Canada
I have the same problem. I opened up my CD960 and this little pin drop out. I cannot figure out where does it come from.
My 960 tray keep open out and not spin when I close it. I dont see the laser light up. Any help? Tks
CD960 tray problem...Hide this!Advertise here!
Sony CDP-101 Tray Problem idealist Digital Source 3 11th August 2007 03:37 PM
Philips cd960 problem muizel Digital Source 0 28th October 2006 01:03 AM
cd80 with tray problem musicfreak Digital Source 0 11th July 2006 12:10 AM
Philips CD960 playback problem diyman Digital Source 1 2nd July 2006 08:40 PM
CD tray problem!!! Anorgan Digital Source 2 28th February 2004 11:47 PM
Copyright ©1999-2017 diyAudio
