Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 2nd March 2007, 07:51 PM   #1
limono is offline limono  United States
Default TDA 1541 problem (ping Jocko Homo)
Hi there
I have Arcam Alpha 5 CD player with overheating TDA1541A chip . I had to add substantial heatsink to the chip to stop crackling distortion out of the player . The question is if the chip with heat sink is operating to its full potential or is it some sort of failure mode?? I'm trying some of the mods (nonos) and passive active I/V with Borbely jfet I/V board (discrete op amp ,buffer filter stage) So far I think I like the active conversion more than passive one (50 Ohm resistor ) with TVC (S&B TX102) pre. I'd like to add a clock upgrade and get rid of SAA 7220 digital filter so what do you think of NET-Audio board ?? ~$100 is a little steep.
I have another 1541 (S1) machine -Mcintosh MCD7007 which is using the same philips chipset so Arcam will be an experiment board. Thank you for any suggestions.
Old 2nd March 2007, 07:56 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Default Re: TDA 1541 problem (ping Jocko Homo)
Originally posted by limono
Hi there
ping
jocko here:
www.diyhifi.org
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 2nd March 2007, 09:59 PM   #3
Bricolo is offline Bricolo  France
Bricolo's Avatar
it's been said several times here that the 1541 runs hot, and it will indeed benefit from heatsinking.
but it shouldn't fail without it, and shouldn't also need lots of heatsinks
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease
Old 2nd March 2007, 11:08 PM   #4
Well , I've got this player recently as "non functional" .It played couple tracks then signal was getting increasingly distorted as to the point it did not play anymore (no sound) It's funny because I discovered the reason by sticking a cold finger (damn cold in Detroit these days) to the chip and bringing it back to life. I simply put some heavy
metal part over the dac while experimenting with I/V stages. No I wonder if I should replace 1541A (not easy to find and expensive) or just keep the heatsink. It's been only recently I'm reading on NONOS dacs since I have those two 1541 machines. Thanks L
Old 2nd March 2007, 11:23 PM   #5
Bricolo's Avatar
having it in a non-os mode will be good in your case, since slower speed means less heat
Old 3rd March 2007, 07:22 AM   #6
Ok screw Arcam :0)
I opened up the hood of Mcintosh MCD7007 circa 1989 with 1541 S1 single crown . I was told it belonged to Aretha Franklin . I grounded and stuffed blue tack around clock quartz , disconnected elaborated audio board with 40 OPamps and IC volume control and took audio output straight from the buffer stage based on NE5532 (one IC on deemphasis other Bessel filter ) Ummm I like it .I decided I'm not potent enough for elaborate mods . I'll order Net-audio NONOS board substituting SAA7220
connect Borbely discrete I/V opamps on the place of dual opamp ,change SMD caps around 1541 for some poly 0.22 . and maybe maybe knock off some more elaborate regs for Dac chip .Did I forget about anything???
Old 3rd March 2007, 08:20 AM   #7
GJF is offline GJF  United Kingdom
Classic TDA1541 failure mode I'm afraid.
Overheating after a short time of operating and steadily increasing levels of distortion!
Try;
www.cricklewoodelectronics.co.uk
TDA1541A £19.00 + VAT and postage
TDA1541R1 £19.00 + VAT and postage
Up until a few years ago they had single crown versions at a lowly £7.00, I bought a pair then for a Sony CDP-227esd that had a chip with the overheating and distortion.
Gary.
Old 3rd March 2007, 09:09 AM   #8
aparatusonitus's Avatar
I used to have the same problem as you limono, and found TDA1541A faulty. After I change it, everything is O.K.
Non é mai abbastanza...
Old 3rd March 2007, 10:23 AM   #9
andrew_whitham's Avatar
The net audio board is thoroughly professional of course, but its actually real easy to convert to non-os
non - OS vs OS, for amusement and entertainment only
Took me an afternoon & cost about 4p. BUT if you are willing to forgo the mute function, (you'll get a click click click as you skip tracks) you shouldn't even need a board.
Take a standard 24 pin chip holder and remove/cut off pins 1, 2, 3, 15, 16 & 18 Then remove the SAA7220 from the CD player - carefully, you'll need it.
Solder in the modified chip holder. Then, using 'as short as you can' wires link the holes 1,2,3 on the player board holes 18, 16, 15. This bypasses the SAA7220. Pop the SAA7220 back in to provide the glue logic.
So long as you didnt toast the '7220 you are now NonOS! if you did the player will sit there and attempt to spin the disc as fast as the motor will allow.
That might be useful to know.
Andy
Old 3rd March 2007, 02:15 PM   #10
I have been wondering about this, specifically how much cooler the chip runs in NOS mode. My NOS TDA1541A reaches 52degC (33 degC avove ambient). Does anyone have any figures for temperarture rise above ambient for this chip when oversampling?
Tim.
AD1853 Dac with Jocko Homo I/V stage yanok Digital Source 8 25th October 2004 09:38 PM
Thanks to Jocko Homo! speaker Swap Meet 1 28th April 2004 04:23 PM
To P-A and Jocko Homo dimitri The Lounge 5 10th July 2003 10:06 PM
Page generated in 0.10848 seconds (82.18% PHP - 17.82% MySQL) with 11 queries
