Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 27th February 2007, 07:33 PM   #1
tubee is offline tubee  Netherlands
tubee's Avatar
Default MK2703 PLL clock in SACD, good or no good?
I have a Yamaha S657 SACD/DVD/CD upsampling player. Have downloaded the service manual to look at the schematics. (philips DVP 720 is allmost the same)
The clock is provided by a PLL chip, the Audio Clock Synthesiser MK2703. Is this any good?
Another SACD player, the Philips DVP 963SA has 3 cristals which are switched (But switching of clock signals is not the best way imo)
What can possibly done to mod the clock of this Yamaha SACD player? I only can think of good bypassing with sanyo oscon near PLL chip.
Daisy Bell
Old 28th February 2007, 07:58 PM   #2
Default Re: MK2703 PLL clock in SACD, good or no good?
it provides the correct frequencies (good), but jitter wise..........
Neverthjeless, these PLL chips provide better clocks if their source is better: Replace the standard crystal attached to these ICs with a better clock and you will bennefit. Decoupling helps, but better take a separate regulator for the PLL chip.
best
Guido Tent
www.Tentlabs.com
Old 28th February 2007, 09:58 PM   #3
Hi Tubee,
Do you have a url link for the S657 manual? I have the DVP720SA manual and would be interested to review the Yamaha.
Presumably this is another co-design like the DVP9000SA / S2500 ?
Jon
Old 1st March 2007, 03:27 PM   #4
tubee's Avatar
Hi Guido
I was hoping allready that you could reply to this question, thanks a lot.
Didn't open the player, but saw indeed in the datasheet of PLL a cristal is used, the block diagram of Philips DVP720 didn't mention about a cristal. I thought the frequency was defined by the PLL chip only. Will upgrad clock to PLL, and build separate (& choked) PS for it.
Hi Jon.
Yamaha S657 has used same Philips mainboard of Philips DVP720, but omitted the eco board and has another keyboard pcb. I could only find 720's serv. manual.
Daisy Bell
Old 1st March 2007, 05:13 PM   #5
tubee's Avatar
The PLL uses MCL from mechanism, and buffers it. No cristal near PLL used, but there must be a cristal found somewhere, i assume near DVD mechanism.
Opamps used: LM833, yuk. Should try LM4562's
Daisy Bell
Old 1st March 2007, 05:33 PM   #6
tubee's Avatar
Here 27Mhz clock source.
Daisy Bell
Old 1st March 2007, 08:33 PM   #7
mcl from mechanism, yuck....
I wouldn't spend too much money, other than to see if replacing the master clock on the mechanism, improves anything
best
Guido
Guido Tent
www.Tentlabs.com
Old 2nd March 2007, 09:29 AM   #8
tubee's Avatar
Thanks for tips Guido.
But this player doesn't sound bad at all out of the box. The cristal freq. must be tapped somewhere else, that's problably why they used a PLL chip afterall.
Daisy Bell
Old 5th March 2007, 09:06 PM   #9
tubee's Avatar
I couldn't hold myself any longer, lifted the hood of the Yamaha. 3 pcb's, switching PS, mainboard and mecanism board. Opamps are 4 smd LM833,s
One cristal: 27000 ceramic smd(27Mhz) near mechanism.
What i could do is build a new and simple oscillator, buffer it with 3 And gates and lead the 3 clock signals to the parts who need it.
And what about this very simple clock: (found it on diyaudio somewhere else)
Daisy Bell
Old 6th March 2007, 06:53 PM   #10
Textbook design, hence no good for serious audio. And no suggestion for a a slicer.......
cheers
Guido Tent
www.Tentlabs.com
is a resolution of 0,001 UI good to measure clock jitter ? Bernhard Digital Line Level 1 8th December 2008 02:01 PM
Good switch for Stepped attentuater, Good cheap RCA jacks pjpoes Parts 20 10th March 2005 08:47 PM
Is TCXO really good for re-clock?? tube-lover Digital Source 43 29th January 2005 10:11 PM
A good universal transport (cd/hdcd/sacd/dvd/dvd-a/mp3)? halcyon Digital Source 3 11th August 2004 01:51 PM
Good clock radio eRiCdWoNg Everything Else 0 5th December 2003 08:21 PM
Page generated in 0.11742 seconds (81.36% PHP - 18.64% MySQL) with 11 queries
