Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Sowter transformer 8347 I/V stage fot TDA1543
Old 27th February 2007, 09:16 AM   #1
elec-tron2 is offline elec-tron2  France
elec-tron2's Avatar
Send a message via MSN to elec-tron2
Default Sowter transformer 8347 I/V stage fot TDA1543
Hello all.
I've built a DAC based on a CS8412 and a tower of TDA1545 (8).
I was planning to put a transformer I/V stage with a Sowter 8347.
All is working when I put just one transformer on one of the TDA1545 output but no sound when I put the two transformer on the two channels !
Is somebody have tried this before ?
I think that Audionote have made the same thing.
Kind regards
Audiophile and audio products designer
Old 28th February 2007, 05:20 PM   #2
NjoyTHEMUSIC is offline NjoyTHEMUSIC  United Kingdom
May I ask what caused you to go for this kind of design ??
-Andy-
I wish I had one more brain cell.....then the one that I've got wouldn't be so lonely (!)
Old 28th February 2007, 08:34 PM   #3
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Sowter transformer 8347 I/V stage fot TDA1543 Sowter transformer 8347 I/V stage fot TDA1543
Did you mean to say: "Since AN did not manage to get good sound this way, why do you want to do the same mistake?"
Arne K
Don't believe everything you think...
Old 1st March 2007, 10:05 PM   #4
phn is offline phn  Sweden
phn's Avatar
Change R7 and R8 to 2k2.
Old 2nd March 2007, 06:38 AM   #5
QSerraTico_Tico is offline QSerraTico_Tico  Europe
QSerraTico_Tico's Avatar
Thorsten Loesch used Audionote's idea here:
http://www.fortunecity.com/rivendell...io/Adagio.html
Old 6th March 2007, 11:18 AM   #6
elec-tron2's Avatar
Thank you for your replies all.
The thing I do not understand is that when I just connect one channel output of the TDA1543, all is working. Tight bass, clear high, really sound great ! But, with the two channels output connected (so the two transformer connected at tht two TDA output) no sound at all ! Just noise ...
Old 6th March 2007, 11:38 AM   #7
phn's Avatar
The Sowter site says you should use a 25Ohm I/V resistor. Mu metal trafos are very sensitive to DC, which should explain the noise. But it doesn't explain why it works when only one channel is connected.
Old 6th March 2007, 11:48 AM   #8
tube-lover is offline tube-lover  Hong Kong
hi,
let me share a little bit opinin. My new full balance dac will use.
1.transformers IV.
2.Op-amp>>>>> transformers output.
3. OP-amp>>> 5687 cathode follower>>> caps OUTPUT.
4. Op-amp>>>>5687 cathode follower>>> transformers output.
this is the first op-amp link with transformer output.
pls see the photo show with the connection method between OP & transformer.
Transformers that I use was 1+1:1+1 10ma Max
thx
thomas
Old 6th March 2007, 04:58 PM   #9
elec-tron2's Avatar
That's true PHN. This doesn't explain at all why this really good work with just one channel.
I have seen too at th Sowter website that I could use a 25 ohm resistor, but what about TDA1543 ?
I have seen too at Sowter that this transformer has been designed for output with a DC component (current or voltage), so I am correct by connecting these transformers without a DC blocking cap ?
I have tried with one and all is working ! All two channels but there is a terrible lack of bass !...
Is Sowter making bad transformers that doesn't support DC offset ?
Old 6th March 2007, 05:07 PM   #10
hi elec-tron2,
sorry to distrub U,
U said lack of bass was talk sowter or my connect?
pls make sure sowter can run dc. Otherwise the core will saturate. I also test 8347f, if pass current looks not good. In my design & est. although I use 1+1:1+1, but this is not a Push Pull ytans. It is a SE trans, can pass Dc. so change Resistors on the pri & sec can adj te sound.
thx
thomas
Sowter transformer 8347 I/V stage fot TDA1543Hide this!Advertise here!
GB: Sowter 10K:10K Input Transformer luvdunhill Group Buys 161 1st July 2013 12:07 AM
sowter 9050 or Lundahl LL1660 line out transformer? mwmitchell Tubes / Valves 13 20th March 2010 10:42 AM
Sowter's Radford transformer theoldtrout Tubes / Valves 0 28th September 2008 11:45 PM
Anyone has comment con Sowter 8920 transformer joeliu Parts 0 15th February 2005 09:35 AM
My experimental I/V stage for TDA1543 Bricolo Digital Source 12 16th April 2004 03:01 PM
