Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Just got AD1955 ref board
Old 9th January 2003, 08:52 PM   #1
schmad is offline schmad
Default Just got AD1955 ref board
I just received my AD1955 reference board. Very nice design overall. I'll post some pictures later.
Measurements are pretty great as well with:
THD+N measurements are typically -108.90762 +- .6dB
Non-weighted SNR is right around -117.87 dB, but has been seen as low as -118.59 dB
Non-weighted DNR is between -118dB and -119.28dB
As for the sound...sounds great to me. I'm not going to talk about "transparency" "musicality" or "fullness" as I'm not a big subscriber to those terms.
The numbers pretty much speak for themselves in my book.
Old 9th January 2003, 09:10 PM   #2
harvardian is offline harvardian
Do you how this board does I/V conversion. Does it have balanced outputs? What are the power requirements?
Does it have any power supply on-board ripple filtering?
Sorry about the questions. I can't seem to find any on-line documentation at the Analog site. Do you have any?
Best Regards,
Dale
doing my part to Keep Austin Wierd.
Old 10th January 2003, 03:16 AM   #3
It uses AD797s, has balanced and single ended outputs, and requires +- 12V.
Yep, it has a handful of SMT electrolytics on board.
It comes with a printout of the schematics and AD1955 docs. You can download the datasheet from Analog's web site:
http://www.analog.com/UploadedFiles/...45AD1955_0.pdf
I don't think the eval board schematics or docs are up there yet.
Old 11th January 2003, 01:24 AM   #4
Hi Again,
Just hoping that you would post some pics.
Does this have switches to set modes or use a PC connection?
What input receiver does the board use or is one not needed with the 1955?
From you rlast post, I assume there is a 5V regulator on-board.
Thanks again,
Dale
P.S. I have one on order. How long did it take them to ship?
Old 11th January 2003, 05:38 AM   #5
Originally posted by harvardian
[B]
OK...here goes:
The DAC is programmable via SPI, a few of the pins on the DB25 are used for that.
For the PCM modes, it uses a CS8414. It also has a seperate input for DSD.
Yep, it's in the north slight left of center.
Took a week and a bit to get here.
Old 11th January 2003, 02:33 PM   #6
A huge thanks!
Best Regards,
Dale
Old 30th September 2005, 10:08 PM   #7
hbarki is offline hbarki  Indonesia
I also bought one. Still have to build the power supply. What kind of power supply are you using?
Old 1st September 2006, 01:23 AM   #8
I connected the board to +-12V. I use the SPDIF input ang RCA ouput. I did not get any sound. Is there anything I have to do to activate this board?
Just got AD1955 ref boardHide this!Advertise here!
ad1955 evaluation board ad1955eb.pdf Mickey Digital Line Level 62 25th September 2009 01:55 PM
WTB AD1955 evaluation board DAC mgm31 Swap Meet 1 13th February 2008 08:27 AM
AD1955 Evaluation board how to activate cruijt Digital Source 3 1st September 2006 01:26 AM
Evolution board AD1955 fantomas Digital Source 1 30th September 2005 10:03 PM
Copyright ©1999-2017 diyAudio
