Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 18th February 2007, 08:48 PM   #1
adyf is offline adyf  United Kingdom
Default sony cdp 333 ESD
hi..
i've got one of these eighties beasts and am having intermittent problems with the TOC reading, the CD's need ejecting a couple of times sometimes before they get read correctly. After that they play fine until ejected..
i've cleaned the lens.. the problem is still there..
does anyone have a service manual or could point me towards any possible fixes?
If I can get this to work reliably, I'm going to try some mods on it.
lots of images and specs from this japanese site:
http://66.249.93.104/translate_c?hl=...3DX%26pwst%3D1
you can use the google translate to translate to an almost english page!http://www.google.com/translate_t
many thanks
adrian
Old 19th February 2007, 05:03 AM   #2
georgehifi's Avatar
Send a message via MSN to georgehifi
This looks very much like the Sony BU-1E laser assembly, if you've cleaned the optics and the trouble is still there, then your last option is to clean both sled rails very well with Metho or alcohol from front to back then with a cotton bud dipped in sewing machine oil lightly re-lube the rails. As this unit is very old, the old lube can get dirty and dry out causing the sled to become sticky.
If all this fails you maybe up for a new laser and they are rare as.
Read these links
Sony BU-1E Laser??????????
Sony X49150331 laser block, help
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 19th February 2007, 09:00 AM   #3
thanks for the reply george.. funny i didn't find your post in my search, i think the search engine is sensitive to spaces or not in the search terms,,
i'll try cleaning the optics and relubing the sled again..
did your replacement assembly go back in ok?
thanks
adrian
Old 19th February 2007, 10:13 AM   #4
georgehifi's Avatar
thanks
adrian
Yep, Bernhard sold me a good one took about 1/2 hr to replace worked perfect, then I sold the 39kg Onkyo.
Cheers George
Old 19th February 2007, 11:09 AM   #5
John C is offline John C  United Kingdom
John C's Avatar
I think I have a service manual for this player... I will have a look L8ter and let you know...
JC
L8TER... JC
Old 19th February 2007, 10:00 PM   #6
thanks john.. that would be great if you did..
i think i've fixed my initial problem...
the main tray sleds were slightly sticky, so i cleaned and regreased these and the tray now moves very smoothly. I also carefully did the same to the rails that the optics run on. This and a lens clean seems to have made switch on TOC reading much better...
I also noticed a loose bracked that appeared to protect the fine ribbon cable from the sliding optic assembly. The screw must have worked loose. Maybe this was related?
thanks again
adrian
Old 20th February 2007, 04:06 PM   #7
John C's Avatar
I have found the manual...
If you e-mail me your address I will send it to you... feel free to photocopy it and return to me at your convenience..
L8TER... JC
Old 14th March 2011, 08:12 PM   #8
Send a message via ICQ to radkosechko Send a message via Skype™ to radkosechko
Default CDP 333ESD service manual
Hi!
Is it possible for somebody to send me a scanned copy of the service manual for the CDP 333ESD please?
I just bought one, had it delivered, and it shows exactly the same problem, no TOC reading and no disc initial spin.
My e-mail is: radko71@avb.bg
Thanks all in advance!!!
Sony CDP-337ESD v Sony CDP-X33ES which is best? eldarvanyar Digital Source 0 10th January 2008 11:04 AM
Sony CDP-711... DoomPixie Digital Source 9 16th May 2007 01:33 PM
Sony PSX-800 fmak Analogue Source 0 18th September 2003 03:48 PM
Page generated in 0.09742 seconds (78.22% PHP - 21.78% MySQL) with 10 queries
