Best quality and lowest jitter Philips transport assembly? - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 8th January 2003, 10:45 PM   #1
Default Best quality and lowest jitter Philips transport assembly?
CDM9 Pro, CD12.4mkI or II, original CDMI or others?
Mark
mburnste@dmc.org
Old 11th January 2003, 06:44 AM   #2
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
How about CD-Pro 2?
http://www.daisy-laser.nl/homeoptics/
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 11th January 2003, 05:53 PM   #3
Banned
Send a message via Yahoo to Elso Kwak
Lightbulb Best Quality and Lowest Jitter Philips Transport
Hi mburnstein,
Unfortunately you don't get a low jitter transport with the crystal hung on the microprocessor.
You can improve the sound by installing a low jitter clock.
See also:
The top secret public KWAK-CLOCK
Old 11th January 2003, 06:10 PM   #4
Default peter
hi,
btw, hows it goin' with your cdpro 2 player ???
best regards,
troels
Old 11th January 2003, 07:09 PM   #5
Transport is done and I'm using it with outboard DAC (PCM 1704). I've been busy recently with gainclones and Aleph X so no NOS DAC done yet.
I bought some 2.5" and 2" thick acrylic panels, so my next player will be base on that material.
www.audiosector.com
Old 13th January 2003, 11:31 AM   #6
Hi Peter,
I'm just playing with a CD-Pro too. Some questions:
How did You connect the PCM 1704? Did You use I2S?
Did You use a DF 1704 too?
Greetings from Germany
Zelter
Old 13th January 2003, 02:10 PM   #7
I used both of these chips, with parallel DACs per channel. I'm using SPDIF, because it is stand alone DAC, but eventually I will end up with integrated DAC using I2S.
www.audiosector.com
Old 13th January 2003, 06:11 PM   #8
Pjotr's Avatar
Some months ago I also looked into the transport as advertised by http://www.daisy-laser.nl/homeoptics/
This is for sure a damn good transport. But concerning jitter: It is controlled by a SAA7324 chip. The clock is generated by a standard c-mos x-tal oscillator circuit. All the audio-clocks are made with the help of a PLL from the x-tal clock. I wonder if this is the way to go for low jitter at the DAC. Because of the PLL circuit I don’t think a good low jitter external clock as Elso did suggest is of much help, regardless if you use the SPDIF signal or the I2S signal.
An external DAC connected to the SPDIF output and with a good jitter suppression is a better way to go IMHO for this nice transport if you want low jitter.
Cheers
Old 13th January 2003, 10:20 PM   #9
Banned
Lightbulb The Chase of Jitter
Cheers
More than two years ago I made a series of postings on the Audio Asylum postulating it makes no sense to tweak the CS8412 as all cause of jitter is in the transport.
http://db.audioasylum.com/cgi/m.pl?f...12&r=&session=
Nowdays I know better and we have at our disposal improved interface circuitry, the Wildmonkeysects loopfilter for the CS8412, low noise analog supply for the PLL of the CS8412 and last but not least my Asynchronous Reclocker. Does this mean that the clock in the transport is not important? I say no as I can clearly hear the difference in clockcircuits applied in the transport, even with all these jitter countermeasures implemented!
I admit I am absolutely not familiar with the CDPRO and I hope the situation is not as bad as you describe Pjotr in a regular CDP.
If Philips is using all kinds of PLL to generate the audioclocks much can be improved by using some deviding scheme instead of PLL's.
How To: Lowest price, max quality hook-up wire KBK Parts 4 7th December 2008 04:10 AM
Sonic Frontiers Transport 3, pickup assembly kwatro Digital Source 1 8th May 2008 09:49 AM
Philips Laser Assembly CDM4/19 inttech1 Digital Source 2 26th March 2008 01:34 AM
How do vibrations in a CD player/transport cause jitter ? percy Digital Source 18 7th April 2006 08:55 PM
Copyright ©1999-2017 diyAudio
