Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 16th February 2007, 08:58 PM   #1
lykkedk is offline lykkedk  Denmark
lykkedk's Avatar
Send a message via MSN to lykkedk
Default Just some picture's of my finished DDDAC...
Finally, i got my dac, in a box.
The dac is a DDDAC 1543 mkII, with s/pdif / usb input, and a single 12xtda1543 tower. - The little pcb at the backside of the dac, is for connecting digital in from toslink or coax.
The dac, had been playing for some time, but i just finished the box today, and now i can't wait showing it.
Doede, the father of dddac, has done a really great dac, easy to get working, and Doede is allways ready to answer some quick quistion's along the way.
The sound from it, is excellent (through my ear's ).... And here is some pics.
DIYAudio crazy.... LeachAmp, PearlPhono, Pumpkin, F4 DualMono, DDDac, HalfChang Spk., LinuxAudio, Squeezebox substitute, Drek inductorloaded pre-amp.
Old 16th February 2007, 09:00 PM   #2
lykkedk's Avatar
Another one !
Old 16th February 2007, 09:01 PM   #3
lykkedk's Avatar
3...
Old 16th February 2007, 09:02 PM   #4
lykkedk's Avatar
Her come's the last one - Have a nice weekend...
Old 16th February 2007, 09:05 PM   #5
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Oeee.....nice build....you must be proud!
Old 16th February 2007, 09:49 PM   #6
Very nice. How warm does it run?
Old 16th February 2007, 09:55 PM   #7
I_Forgot's Avatar
Originally posted by lykkedk
Another one !
It looks very nice, but your RCA connectors appear to be grounded to the box. In analog circuits this can result in ground loops that make amplifiers hum. In digital circuits the added ground noise can result in higher jitter (if you care about such things).
Usually, the best way to ground input/output shielded-type connectors is to isolate them from the chassis and run shielded or twisted cable from the connector, including the ground lug, to the ground on the PCB and then use a single point to connect the PCB to the chassis.
The power supply ground should also connect to that point.
I_F
Old 17th February 2007, 05:47 AM   #8
lykkedk's Avatar
Thanks for the reply.
The DAC, is what i call thermic stable, e.g, it runs good handwarm 40-50 degree C.
It's powered from a 12vdc battery, when i turn off the dac, the charger, charges the battery.
The shield is taken from the little pcb, at the back of the dac, the cables to the shield is no longer than 30mm. The dac is completly quiet.
Ohhh... i didnt no the issue with the jitter thing (have to learn every day thanx), which could be caused by shielded rca, i will consider making that, when i get my hand on some isolated rca's., don't know if it make's any difference.
Both the usb and s/pdif part are clocked with a tent clock. and the dac is sounding beautiful...
Old 17th February 2007, 12:47 PM   #9
gjash is offline gjash  Japan
Very nice looking case! Where did you get it? What are the switches in front? I'm a total newbie but my first project will be something similar.
greg
osaka, japan
Old 18th February 2007, 05:55 AM   #10
lykkedk's Avatar
The case is diy... Made of 3mm alu / 3mm acryl. The big switch in front is from conrad electronics, germany.
Clear picture picture of KSS-273B eledora Digital Source 0 27th October 2007 01:10 PM
Finished Dac Picture maartentje Digital Source 3 1st March 2004 05:10 PM
P3A mono blocks finally finished (picture post) sobazz Solid State 12 31st August 2003 08:36 PM
Finished ESL picture (finally!) phishead8 Planars & Exotics 23 21st November 2002 07:55 AM
Page generated in 0.09581 seconds (79.24% PHP - 20.76% MySQL) with 11 queries
