| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#41 |
Increasing the slope (dV/dt).
But if they don't swich identical enough, th possible drawbacks (at least jitter) are important. I wonder about the two signalwise unused gates and how to use them to improve the seemingly bad signal quality of the input circuit. Maybe switching them to 'high state' (with an additional gate) when the other gates switched to 'low state' can somehow compensate the switching load on Vss, or something like that.
You know that's it: receive and transmit (Peter Gabriel |
#42 |
Now I think that parallizing output stages increases di/dt (if needed!) and dv/dt will only change if the load didn't get enough current from a single output stage. Btw., it's said that the YM3823 receiver is jitter sensitive, so I use a SRC2000 to ensure low input jitter to the DA500. I get a tighter and (unexpected) bassier Sound with coax wire than with toslink. At the output I use a Jensen transformer, who adds a few dB k3 that gives the sound a more realistic attack (prob. steeper dv/dt). .
#43 |
The unused second output of the power transformer (U=8.5V without load)
can be used for digital supply with a low voltage drop 5V regulator etc. (L7805 won't work because Io=250mA).
You know that's it: receive and transmit (Peter Gabriel Last edited by 210; 13th January 2012 at 07:51 PM. Reason: edit |
#44 |
diyAudio Moderator Emeritus
7805 will work OK, I used it for this purpose. You will need a bridge and filter cap of course. And a heatsink.
It's only audio |
#45 |
Any standard TO-220 package 7805 type is capable of 1A with proper heatsinking.
The problem with the YM3623 is not so much jitter sensitivity as poor PLL phase noise performance, inducing more jitter. I know at least ASE sells an adapter board to take YM3823 to DIR9001 or CS88414(forget which, maybe both), which would be a worthwilre upgrade on this dac, which can sound really terrific with the right work done and a respectable transport/server. |
#46 | ||
The voltage drops below the needed 2V difference of the 7805 (tested with 2) with my DA500. I think, this is the reason, why Denon finally didn't use the second wiring of the transformer for digital supply (as they planned, there are a few more 'workarounds' in the layout). I use a coil with common mode cancellation wiring to avoid coupling digital and analog via the transformer. Quote:
Latest when 3623 died and hard to get, I'll try it. I use myca caps for the oszillator, rubber-damped the quarz and use a little, grounded steel case screen above them till then. Regards,
#47 |
Hi, I just got a DA-500 which is already somehow modified. The PSU has two big 10.000uf capacitors, so that I ask myself how the rectifying diodes have survived.
I have now seen that there is a "kill the clock mod" possible, which surpresses disturbing signals from the clock. In this thred are two schematics shown. I have seen, the the small diode 1N41448 is linked to pin 21 once in this and once in that direction. Is this a printing mistake? Kind greetings, Werner |
| Denon PMA-560 | sparkle | Solid State | 16 | 6th November 2010 06:07 PM |
| Need Help on Denon DCD-S10 | Noak | Digital Source | 64 | 21st February 2009 11:45 PM |
| Denon PMA-655 | elec972 | Solid State | 0 | 23rd November 2008 02:42 PM |
| Denon PMA-250 | edl | Solid State | 3 | 6th November 2006 11:59 AM |
| Denon Pma-860 | ManUtd | Solid State | 4 | 11th January 2005 08:14 PM |
| Page generated in 0.09927 seconds (81.69% PHP - 18.31% MySQL) with 11 queries |
