Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
opamp substitution ----> Which one?
Old 8th January 2003, 11:24 PM   #11
Tube_Dude is offline Tube_Dude  Portugal
Tube_Dude's Avatar
Default Connection Diagram
Hi Snake...
The pin function of the NJR5532 of 9 pins are
1--V+ (internaly conectd to 9)
2--A output
3--A - input
4--A + input
5--V -
6--B + input
7--B - input
8--B output
9--V+ (conct. to 1)
Jorge Santos
Old 9th January 2003, 12:07 AM   #12
Wombat is offline Wombat  Germany
Wombat's Avatar
@ m60gpmg
Here we go again!
As you can see none of us can give a unique advice
But for sure it depends on the design your CD-Player delivers
and how therefore an OP amp behaves in there.
All i can advice you is to make some tests on your own.
This NEC4570c is relative slow against the so called good ones. I bet
there will be a better one for you.
You have only one IC to swap, so it won´t hurt to buy 3 or 4 OPs and an
IC-Socket to start your own tests.
I would recommend to buy a cheap NE5532, a philips one when its possible.
One from the Brownies OPA2604 or OPA2134.
An OP275, one of the circuits many like a lot.
And finally a really fast settling one like the AD826 or LM6172.
None of them is bad sounding. There can only be some problems with the really
fast ones due to the board layout, like flickering in the TV next to it
With this selection you can find one that fits and if you like it you can
enter the never ending story even more.
This way i found my favourites.
If time permits - stuff some parsley in your ears and listen how it grows!
Old 9th January 2003, 09:25 AM   #13
m60gpmg is offline m60gpmg
Default thanks to everybody
With this selection you can find one that fits and if you like it you can enter the never ending story even more.
thanks of the suggestion I will do as you say
Thanks to everybody!
Best regards,
m60gpmg
Old 17th April 2003, 02:22 PM   #14
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Finally I found a datasheet of C4570. Maybe it is useful for people that want to replace C4570 for something good:
http://www.ee.nec.de/_pdf/G10528EJ6V0DS00.PDF
It's only audio. Member of the non modular PCB design committee
Old 17th April 2003, 02:58 PM   #15
fedde is offline fedde  Netherlands
Send a message via ICQ to fedde
You should have asked me...
Fedde
Old 17th April 2003, 05:03 PM   #16
jean-paul's Avatar
Hi Fedde, it was Per-Anders that asked for it.
I still dream of a free datasheet-database on the web. Makes life easier for all of us when the companies delete theirs when you need them.
Old 17th April 2003, 05:13 PM   #17
You mean something like:
http://www.chipdocs.com
(thanks to Google...)
Fedde
Old 17th April 2003, 05:14 PM   #18
whoops, sorry not free... :-(
There is a free one though, I'll try to find the link again...
Fedde
Old 18th April 2003, 08:42 AM   #19
Jesús Puerto is offline Jesús Puerto  Spain
Default Cobra2
I did the same modification in Luxman CD
I changed it for one OPA2134 the change was better, only carefull becouse is neccesary that you respected the pin out,
also you need to make a little PCB to adapter the differents package outline,so
you can see an example in the www.lcaudio.com,
I have the datashett NJM5532 and I´ll sent you in PDF format at your email.
Jesús Puerto
JPJ
Old 28th April 2004, 06:55 AM   #20
Fin is offline Fin
Fin's Avatar
Default Replacing opamps
Hi all
My CDP has a NJM5532 opamp in the output stage. I am interested in changing this for something better.
I know that opamps like OPA2134 and OPA2604 are drop in replacements physically, however, are any changes to the circuit/surrounding components required or advised?
I am also interested in Sparhawk's comments about replacing a dual opamp with two single opamps.
Are the Brown Dog adaptors used for this any good?
Do they introduce additional problems by moving the opamps further away from the PCB/groundplane?
Is there another/better way to do this?
Fin
opamp substitution ----> Which one?Hide this!Advertise here!
GZ37 Substitution? Hackensack Tubes / Valves 7 25th April 2014 10:37 PM
Capacitor Substitution d5post Parts 7 3rd May 2009 01:59 PM
6N1/6N3 substitution woodturner-fran Tubes / Valves 7 31st January 2007 02:15 PM
Single supply opamp - unequal rail voltage and opamp selection Hans L Parts 8 19th February 2006 03:15 PM
11k resistor substitution...? mcelaj Solid State 3 6th January 2004 05:31 PM
Copyright ©1999-2017 diyAudio
