| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi
I have a question about a spdif DAC design using dir1703 and tda1543. Can I build it like this:(attached) Is it right to select "16bit msb first right justified" and 128fs? If it is not, then is it possible to build a dac from these chips only? kind regards Adam |
#2 | |
Well I assume it's I2S but it's listed as IIS! (I haven't looked at the timing diagram though) Not sure about 128fs.... |
#3 |
Why should I use 24 bit output mode from spdif receiver if tda1543 is 16 bit DAC?
I think I should choose 128fs, because maximum frequency at clock input of tda1543 is only 9.2MHz, is that right? |
#4 | |
#5 |
I understand, yes, that's the only i2s mode and is marked IIS. Thanks to both of you.
Another question: what crystal should I use? can it be 12.3Mhz? |
#6 |
Corrected receiver/dac
(FMT pins connected to HIGH) |
#7 |
How I'd imagine spdif input
#8 |
Simple and not very sophisticated IV stage with analog interpolation in attachment.
I would again invite the experts to comment, I am a true novice to DAC design and do not want to burn much silicon. regards |
#9 |
Why are you using TDA1543? It's not a NOS design, since you have the DF. I just don't get it. AFAIK, the only reason to use TDA1543 is for NOS designs. It's not as if the specs of TDA1543 by themselves are so great.
#10 |
DF ?
What do yuo mean by this abbreviation? |
| Would this work ? | LesPaulStandard | Instruments and Amps | 3 | 4th May 2006 02:14 AM |
| Will This Work? | sousmielie | Class D | 6 | 27th December 2005 05:53 PM |
| It Should Not Work ! | f4bok | Solid State | 3 | 6th September 2004 05:33 PM |
| Would this work? | JoeBob | Solid State | 5 | 18th July 2003 03:40 PM |
| Page generated in 0.09830 seconds (80.42% PHP - 19.58% MySQL) with 11 queries |
