Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
S/PDIF Optical to S/PDIF RCA Replacement
Old 2nd February 2007, 11:01 PM   #1
PrecisionAudio is offline PrecisionAudio  United States
Question S/PDIF Optical to S/PDIF RCA Replacement
Hello. Is it electrically possible (and easy) to replace an S/PDIF optical jack with an RCA one?
I ask because my PCI audio card has an optical jack but my JBL LSR monitors have RCA jack digital inputs. So, I was thinking I could scavenge an RCA jack from an old, dead piece of equipment and solder it up replacing the optical one.
Yes, I am unaware if there are any data protocol differences and that's why I'm asking.
Note: there is an add-on ribbon-cable-connected "daughter" card to connect to the existing PCI card that would provide an RCA digital jack but it is extremely hard to find and so expensive to not make it worthwhile. Ergo, my jack replacement question.
Thanks for any thoughts!
Joe
Old 8th February 2007, 03:59 PM   #2
lucpes is offline lucpes  Romania
Send a message via Yahoo to lucpes
If you're looking for a "quick & dirty" sollution then look onto the soundcard board. The optical transmitter has 3 pins. Digital, ground and 5V as far as I remember. You can take the signal from there through a say 0.2uf polypropylene coupling capacitor, but make sure that the monitors you are using can withstand 5V levels on the digital input.
We should no more let numbers define audio quality than we would let chemical analysis be the arbiter of fine wines. Measurements can provide a measure of insight, but are no substitute for human judgment. Nelson Pass
Old 11th February 2007, 09:35 PM   #3
Thank you for your thoughts on this! I greatly appreciate it and will investigate further. I'm not knowledgeable of the digital protocols (of the electrical signal) but thought I'd ask the forum.
Sincerely, Joe
S/PDIF Optical to S/PDIF RCA ReplacementHide this!Advertise here!
Optical 2 S/pdif converter? Ryssen Digital Line Level 21 29th January 2009 11:05 PM
USB to S/PDIF conversion zagisrule! Digital Source 16 14th August 2007 04:52 PM
Digital volume control with remote and optical S/PDIF DEQ+TheEnd Digital Source 0 21st November 2005 03:58 PM
S/pdif borges Digital Source 9 5th March 2005 12:22 AM
