Trio (Kenwood) DP-1000, Any info? - Page 4 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 29th March 2007, 05:12 AM   #31
hadihf is offline hadihf  Pakistan
Default Part 5 of 9
5 of 9
Old 29th March 2007, 05:14 AM   #32
Default Part 6 of 9
6 of 9
Old 29th March 2007, 05:15 AM   #33
Default Part 7 of 9
7 of 9
Old 29th March 2007, 05:17 AM   #34
Default Part 8 of 9
8 of 9
Old 29th March 2007, 05:19 AM   #35
Default Part 9 of 9
9 of 9....
Old 29th March 2007, 05:27 AM   #36
Default Remote control
I will appreciate if somebody post a good picture of DP-1000 remote Control unit so atleast i know how it looked like.
Old 1st April 2007, 01:30 PM   #37
GJF is offline GJF  United Kingdom
Can't help with a picture at the mo', but the model number of the remote is; RC-2000 if that helps.
Nice one with the schematics!
Old 30th June 2008, 05:58 PM   #38
Default Difference between DP1000 and DP2000?
hi,
i would like to know if there is a big difference between the DP1000 and DP2000. since i have the DP 2000 and the track indication dosnīt work. the player itself works fine. by the way, dose anyone have a service manual for the DP2000? or can i use the manual from the DP1000?
thanks in advance
manfred
Old 7th March 2011, 08:56 PM   #39
fonon is offline fonon  Poland
Originally Posted by GJF View Post
the only fault is a sticking loading draw.
A quick look-see inside reveals what appears to be a stretched belt and a need for lube on the loading mech.
Could You write more about fixing this problem? I have DP 1000 and similar problem.
f.
Old 8th March 2011, 06:10 PM   #40
What happens is that the tray loading motor belt stretches and then the magnetic clamp is not pulled off the spindle that the disc sits on.
If a disc is left in the player then this problem is only noticed when the tray is closed with no disc in at which point the draw refuses to open.
Just fitting a new belt completely fixed mine and that was nearly 3 years ago.
I still use this player occasionally now!
Still plays everything including cdr's and has never mistracked anything, not bad for 27 years of age, I love it!
Seeking info: researching the Trio Kenwood L-07D for a magazine article Triophile Analogue Source 4 9th August 2009 05:42 AM
TRIO / KENWOOD L-05M Monoblocks Repair Thread poynton Solid State 5 2nd August 2007 11:07 AM
Trio/Kenwood CS1575A help lumanauw Everything Else 0 1st November 2006 06:48 AM
Trio (kenwood) LS-77 PTSOUNDLAB Multi-Way 5 7th April 2006 09:04 PM
FS: Kenwood (TRIO) L-05M and L-07MII MJR Swap Meet 1 8th September 2003 01:16 AM
Copyright Đ1999-2017 diyAudio
